Question about Dishwashers
Why are lights flashing
Frigidaire model gld2150rcs0
  • 17,130 Answers
Possible that the main board has errors and needs a reset.If there is no result it can be due to errors in the system control or a possible failure in the processor. Check for a reset by removing power for a while.
Posted on Dec 31, 2012
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
Frigidaire front load dryer not drying all panel lights flashing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2015 | Frigidaire Dryers
Oven lock light is flashing and oven is not working. What to do
Hey friend, thank you for your post!
I see your oven lock light is flashing and the oven is not working on your Frigidaire range. Are you able to provide model number, with that information I can research any additional information for your range. You can locate the serial tag (which lists your model number) behind the bottom drawer of your range. Thank you for the post and I look forward to assisting you. -Matt
Sep 28, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
The hi temp wash and air dry lights are blinking on my firgidaire dishwasher
Hi Dan, this is AP!
I understand you are experiencing some trouble with the lights on your Frigidaire dishwasher. On your particular model, FFBD1821MW, if there has been a power failure, then the "Hi-Temp Wash" and "Heat Dry" LEDs will flash. In order to stop the LED lights from flashing press Start/Cancel. This process should relieve your concern regarding the LED lights flashing. I hope this information proves helpful to some degree.
Best of luck,
Mar 25, 2014 | Frigidaire Dishwashers
Frigidaire Washer acting strange
when lights flash the unit is indicated an error message, count the blinks and which lights are flashing, then seek out online what error could be. also, very common issue is clogged drain hose filter inside machine, service company should be contacted to properly take apart unit and repair.
Apr 03, 2013 | Frigidaire Washing Machines
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
Door lock light flashing, door will not open
if it has a kick plate on it take it off and see if the filter is clogged
Apr 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Panel resets
Hi Tim, there was a service flash out on this model which has to do with the circuit board in the dispensor. Frigidaire has redesigned this board causing your problems. This should be covered under this service flash. The number of the service flash is 46-470. The solution is to replace the water filter and dispenser board. Contact Frigidaire and inquire about the service flash. Refers that were included in this flash have the serial numbers between LA113---- to LA146----. If yours fall into this range you should be covered. Circuit board kit number is 240533603. Your model is included in this flash...Catriver..post back.
Aug 21, 2006 | Frigidaire PLRS267ZAB Side by Side...
Dishwashers Logo
Top Dishwashers Experts
