Question about Toshiba Satellite A105 Notebook
My laptop wireless adapter is not working
I have a wireless mnetwork within range but my wireless device does not seeit i can went to check the device manager list to see if my wireless adapter is actually working but i only see the fast ethernet lan adapter working properly i also check the wireless zero configuration to see the wireless device was started .it was started and even the wireless swicth was on but still cannot see the wireless network within range. i guesss i need a driver to make it work pls help.am getting frustrated.
  • 535 Answers
See the wiress btton on laptop its on or off chak it if its on then remove and reinstall your wireless driver
Posted on Jan 18, 2009
My adapter speed never goes over 11Mpbs even though it did on another computer and when I first connected it to this laptop. The signal strength is excellent and never drops out. Is it a software problem?
Laptop computers has more restrictions than any other regular desktop computers.
You may need to check if the firewalls in your laptop is enable. Using any wireless device will best work if the firewall setting in the laptop is disable.
Hope this help!
Dec 25, 2010 | Sabrent NTWGHU HighPower 1000mw Wireless...
Wont let me connect to my wireless connection
make sure you are within range, verify that your wireless adapter is enabled in the BIOS, reinstall the wireless driver, and make sure you are using the system with the AC adapter. check if any devices like microwave over are near. resetting your wireless router is another thing you can do.
Oct 17, 2009 | Acer Aspire 5315 Notebook
Wireless connection Dell Latitude E6400
Look for a switch that turns on the wireless device. Also check in the connection manager if the device is active and the wireless adapter is within range.
Aug 14, 2009 | Dell Latitude E6400 Notebook
My wireless adpter is not working
try downloading new drivers for your adapter and
try again .i had the same problem.new drivers worked fine
hope this helps
Jan 18, 2009 | Toshiba Satellite A105 Notebook
Acer aspire 3000
1. this one is obvious but is probably best to check.. are your access points broadcasting the ssid? if not get that fix first or manually configured your workstation by entering the ssid you had configured in your access point with the respective pass/key
2. did you download the correct driver? check in device manager for any ! or ? next to your wireless adapter (network adapter) then do the following if any:
a. rollback to the previous driver by doing a driver rollback (device manager, device properties, driver tab) then test.
b. uninstall and reinstall the driver that you got from the laptop manufacturer, check the model is the same correct one.
Nov 07, 2008 | Acer Aspire 3000 Notebook
My HP wireless doesn't work? I don't have wireless connection on my compaq laptop anymore.
check your wireless adapter is on... the switch is on the front of your laptop and you should show a blue light when it's on, also go into device manager and see network adapters.. you should have 2 (the wire one built-in and your wireless network adapter.. if you only have one network adapter, check the front and see if the light indicating the status of your wireless network adapter is amber.. (if it's showing amber and you're sure it's in the on position you may have a motherboard problem and you may need to send the system back (I just had one of those with a compaq computer and since the item was within warranty the fixed in a week)
if your wireless adapter light is blue and you see your wireless adapter in device manager follow this instructions and you should be ok,
vista
http://www.home-network-help.com/vista-to-connect-wireless-network.html
xp
http://www.home-network-help.com/wireless-adapter.html
Oct 03, 2008 | Computers & Internet
On my laptop, I cant connect with wireless connection.
1. were you ever able to do it before?
2. first.. check your wireless adapter is on and you have a light showing you adapter is on (blue or green).. on some compaq laptops if you get an amber light and the switch is on the on position the wireless adapter may be faulty and your motherboard may have to be replaced.
3. check also you are within range of your access point (router).. usually on the system tray (where you clock is ) you will see icons showing you are within range or not (ex. a computer flasing a little blue light with some waves to right).
4. find if your computer detects your wireless adapter (go into start>right click my computer>properties>hardware tab> device manager... and look under network adapters! if you see your wireless adapter make sure you don't have a ? or a ! sign next to it.. if you do you may need to update the driver or reinstall the driver of this device. check the cd that came with the adapter or using another computer download the setup file/driver from the hardware manufacturer of your device and using a flash drive move it to the system you're working on and install the appropiate driver for your operating system.
Sep 21, 2008 | Computers & Internet
Wireless Internet For Laptops
Some access points have codes, your laptop has to be able to pick up a access point. But in 2012, There will be a thing called Wi-max which means Wireless internet will be all over the world no matter where you are. So you can go on the internet wherever you are as long as you can connect to someones access point.
Jun 11, 2008 | Internet Computers & Internet
Hi I have for
is your adapter recognized in the device manager?
Feb 15, 2008 | Computers & Internet
Keep getting kicked off
usually the problem like this was cause by unupdated firmware of either you wireless card or router. check the manufacturer of both devices and check the website if there is any updated firmware of both. you will also find instructions on how to upgrade the firmware on the manufacturer website.
Feb 11, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Toshiba Satellite A105 Notebook Logo
342 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
