Question about KitchenAid K45SS Classic Stand Mixer
No rotating movement from the mixer, only fast clicking sound after beater was lodged.
The metal cap that is removed for the grinder & pasta attachment was not secured with the pin and fell into the bowl while while mixing cookie dough. Unfortunately this lodged the beater bar, everything "locked up". No rotating movement only a fast higher pitched clicking type sound. Definite damage done...is this repair worthy? The Heavy Duty mixer series is only 5 years old.
    Novelist:
  • KitchenAid Expert
  • 185 Answers
This is an excellent mixer and worthy of a professional or DIY repair.. You stripped a gear inside the mixer that is there just for that reason. Now the machine requires a tear down and replacement part. if you can post the model number we can advise on how to do it. If it is the new pro series model they cost between 4 and 5 hundred new to buy, the repair is going to cost between 80 and 100 dollars by a professional or about 30 dollars by you.
Posted on Mar 24, 2013
  • 9 Answers
SOURCE: Motor runs but the beater does not move
you most likely stripped the plastic gear (Worm gear???).  This gear is designed to fail to prevent the motor from burning out under EXTREME loads (i.e. when a metal piece falls into the bowl). The plastic gear is much cheaper than a new motor.  Look around on this site to see how to get at/repair the gear.  I've found many parts on eBay.com and also PartSelect.com.
Posted on Jan 27, 2008
maklean
  • 1665 Answers
SOURCE: Bowl won't lock into Place
hi have a nice day.
At the link below you can find illustrated instructions of how to repair a food mixer.
http://home.howstuffworks.com/how-to-repair-small-appliances4.htm
Does it help?
Posted on Feb 23, 2008
SOURCE: Kitchen aide mixer
i noticed my kitchen aide mixer is sounding like it is bogging down slightly while it is running it is not used very much and bought christmas 2007 others who own them have said theirs doesnt do that should i be concerned
Posted on Sep 05, 2008
  • 130 Answers
SOURCE: mixer head loose
Referring to the diagram on:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
Remove the screw, item 22, to remove the trim band around the mixer. This will reveal 4 screws which hold the top cover on. Remove the screws and lift the top off. Find all the screws which hold the gearhead in place and tighten them all. If you want to make the fix a permanent one put some thread-loc compound on each screw and tighten it.
Posted on Mar 30, 2010
  • 130 Answers
SOURCE: Top wobbles and beaters scrape bottom of mixing bowl when in use
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Posted on Apr 08, 2010
Need help getting food grinder attachment troubleshooting cant get mine to operate
When you use an attachment the mixer will still stir. You need to remove the beater when using an attachment.
Mar 04, 2015 | KitchenAid K45SS Classic Stand Mixer
Is the mixing gear supposed to turn when the pasta attachment is on? (KV25MCXER)
Yes it will turn, just remove the beater. It is a solid drive and cannot disengage from the motor unless you overload it and wreck the fuse gear.
Nov 24, 2013 | KitchenAid Food Mixers
The mixer won't work the pasta attachment, keeps rotating the mixer motor.
It sounds like it could be a possible stripped gear. You could have a bad attachment drive gear or bevel pinon gear.
Best thing to do would be to take the mixer apart, and inspect those gears. Here is a link to the service manual which will aid you in taking apart your 4.5 quart mixer: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Here is a link to the attachment drive gear: http://www.mendingshed.com/attachmentgear.html
Here is a link to the bevel pinion center gear: http://www.mendingshed.com/pinionwormgear.html
Let me know if you have any questions.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 27, 2013 | KitchenAid K45SS Classic Stand Mixer
My KitchenAid Professional 6 mixer has been used about 2 years. Lately it leaves a black trail in my icing/batter/whatever from the finish being worn off the metal beater--the triangular one. The bowl has...
It sounds like you have two problems. First, the black marks are usually because of a reaction between the beater and certain chemicals used in dishwashers. Try washing the beater by hand and scrubbing it throughly to remove any residue. If this works, don't use the dishwasher again. You could also buy a plastic coated beater.
It also sounds like the bowl height needs adjusting. There is a screw just under the head for this.
Jan 08, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Motor turns and the top shaft turns as does the grinder attachement but the bottom shaft does not turn. The grease is clean (no metal filings) I can't figure out how to remove the main shaft to see were it...
sounds like you sheared the key on the on the ptanetary to main shaft. remove planetary of mixer. you will see how main shaft is keyed to planetary. replace key reassemble , and you will be mixing agian, dont forget to vote, thanks, monomoy
Oct 03, 2009 | Hobart D300 Stand Mixer
Mixer turns on but the beater doesn't rotate
Remove the metalic ring around the mixing head. Push down on it with a flat head screwdriver...
Remove the pin from the mix shaft.
Pull down on the mixer head. Inspect the gears.
If nothing wrong here, disassemble completely and inspect drive gears. Something is broke and needs replaced. You need to find it first, then take that broken part to the dealer to get a new one. Good luck
Feb 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Need bowl and mixer attachments for Kitchen Aid Artisan Mixer
We've found most all accessories at any place that sells the mixer. Bowls, beaters, meat grinders, pasta makers, etc.
Jan 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
Kitchen Aid switching from mixer mode to grinder
There is no switch. When you have the accesory in the front, the beater section still moves. I suggest that you remove the beater so that there is less possibility for someone to get hurt.
Nov 07, 2008 | KitchenAid KSM150PS Artisan Series Stand...
How do I remove the metal cap above the whisk? I want to use my new ice cream maker but the attachment won't fit unless I take off the metal cap. I've tried everything but it looks like there's no way of...
your not supposed to remove the cap. under that cap is just a gear assembly that powers the beater assembly. some of these attachments are only compatable with certain units. some of the older units arn't compatable with the newer attachments.
May 06, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
197 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
