Question about GE GSS25LGM Side by Side Refrigerator
GE PCG23NHMF side by side fridge freezer - stopped cooling
There is a continuous noise (fan/compressor?). The appliance was apparently working but the food in the freezer has started to defrost. Have tried stopping and starting and adjusting temperature. But is not cooling the food.
  • co_chill Jan 22, 2009
    The food in the freezer is defrosting and refridgerator side is not cold this is the second time i thawed out the coils in the back of the freezer but it happened again is there a part thats bad or what
Although this machine is supposed to be frost-free (i.e. automatic defrost), there was a build up of frost. We manually defrosted the machine, then restarted it - the noise has stopped and the freezer and fridge are now working. However, this may be a temporary solution.
Posted on Jan 19, 2009
GE profile not cooling
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running. First, answer these questions: Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these: The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor
Mar 28, 2010 | Refrigerators
Not cooling
it could be a thermostat or it could be the relay on the back of the fridge. the relay on the compressor may be bad. pull the fridge out and see if you can feel the compressor. and see if it is hot and if the fan is blowing... if not replace the relay.
Aug 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge & freezer not cooling. Meat thawing
Mar 28, 2010 | GE Profile PSW26P Stainless Steel Side by...
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Ge profile artica not cooling
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Aug 16, 2009 | GE GSH25JFR Side by Side Refrigerator
    Kenmore side by side is not getting cold or freezing
    The compressor
    The Thermostat
    The defrost timer
    The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
    Regards:
    VOTIT
    Don't forget to rate;
    Jul 05, 2009 | Kenmore 53642 / 53644 Side by Side...
    Fridge/freezer inoperative
    does your fan work in the back of the unit. Either that or it could have been your compressor
    Dec 23, 2008 | GE GSS22JF Side by Side Refrigerator
    Fridge and freezer on GE GSS25SGMDBS not working
    • The compressor
    • The Thermostat
    • The defrost timer
    Jul 26, 2008 | GE GSS25SGMBS Side by Side Refrigerator
    Refrigerator not cooling
    • The compressor
    • The Thermostat
    • The defrost timer
    Jun 12, 2008 | GE GSS25SGMBS Side by Side Refrigerator
    Samsung RS2555SL humming noise
    don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
    Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
    GE GSS25LGM Side by Side Refrigerator Logo
    370 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
