Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Our GE Profile refrigerator with freezer on bottom is leaking water on the floor. There is ice build up on the back of the freezer compartment. Water stopped leaking when the filter was taken out. I cleaned all the ice out of the freezer and within 15 minutes the bottom section is almost completely frozen over.
    Problem Solver:
  • 24 Answers
GASKETS PLAY AN IMPORTANT PART IN THIS PROBLEM, DEPENDS ON HOW OLD YOUR APPLIANCE IS YOU COULD CHECK IF YOUR GASKETS ARE WORKING PROPERLY BY SETTING A SHEET OF PAPER BETWEEN THE GASKET AND FRAME AND PULLING THE PAPER OUT SHOULD HAVE A LITTLE RESISTANCE, IF PAPER SLIDES OUT WITH NO EFFORT IS A SIGN OF BAD GASKETS, THAT ALLOW MOISTURE TO GET IN AND CONDENSATE AT THE BOTTOM.
Posted on Aug 06, 2013
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
SOURCE: Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Posted on Jul 16, 2009
woodchuck789
  • 4059 Answers
SOURCE: GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 17, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
I have a GE profile performer fridge ,with freezer on bottom there is water and ice build up at back of compartment, almost looks like a drain usually leaks out on floor in front of freezer compartment.
drain is frozen up. unplug and leave bottom door open for 24 hours and may be ok. Only alternative is to remove the bottom of the fresh food section and de-ice with blow dryer. If it does it again then the Styrofoam between frig and freezer must be replaced.
Oct 27, 2010 | Refrigerators
Ge profile leaking water from bottom of appliance
if you have ice on freezer floor, then you likely have a clogged defrost drain. the meltwater from the evaporator can no longer reach the condensate pan under the unit. Unfortunately, the only way I know how to unclog it, after removing all the ice, is to blow compressed air from the freezer into the drian, to force out the debris.
if you have no ice on freezer floor, then from my experience, the problem is due to a dried, brittle and cracked water line for the water dispenser. Pull the fridge out from the wall carefully, you will see a machine compartment cover at the bottom. If this cover is only half as wide as the unit itself, then due to the proximity of the water valve to the compressor, the water line is very well known to crack. You will have to replace the 5/16" water line from the valve solenoid to the water tank located inside the refrigerated compartment.
If neither of these scenarios cover your problem, i would advise seeking a competent repairman. If you are in chicagoland, I can help, otherwise no.
Mar 01, 2010 | GE Profile PSI23NCR Side by Side...
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water build up back of freezer inside drips to bottom and leaks from under door.Looks like their is some sort of tray with hole in back then it overflows drips to bottom of freezer some of water freezes...
Our GE Profile leaked from the freezer door and this is what I was told by a service man to try before he came and it worked. There should be a "well" on the bottom of your freezer floor where the water runs when it defrosts. Yours is probably now covered with a sheet of ice. You can melt the ice with a hairdryer using dry towels to soak up the water as you work or really hot wet rags and ring them out in the sink. After all the ice is removed pour a small amount of warm water into the "well" and stick your finger in there and "plunge" it - like you would a clogged toilet - with your finger. This will purge the ice that blocked the drain. Check on this every couple of months to make sure you don't end up with the same problem in a year or so.
Jun 12, 2009 | GE GSS25JFM Side by Side Refrigerator
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Ice build up
Same repair as water leak on floor. unplug, remove back inside panel of freezer, clean out drain hole.
Jan 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
150 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
