Question about Mach Speed Tablets & eReaders
My tablet keeps saying authentication problem?
Will not connect to wi-fi at all authentication problem?
  • 11800 Answers
SOURCE: wireless internet access
A wireless 802.11b LAN adapter is included in you tablet, activate it thru Control Panel / Wireless. Unfortunately this is the first generation standard and as such is extremely slow, has very limited range and is no longer supported by a lot of the newer generation devices/hotpoints.
Posted on May 24, 2010
rcw1962
  • 2571 Answers
SOURCE: my wi fi is not connected. How do I do that/
I picked 1 up for the first time and connected in 2 minutes.
In settings page where you add a wireless connection, you will need to know..
Security type, mine was wpa2 ( may be wpa/wpa2/wep)
SSID, your network name that is transmitted, mine was default
password, whatever the wireless password you chose with wpa, if you have wep, it gives you a pass key, you will need to log onto your router to get this
Posted on Jul 17, 2010
  • 8 Answers
SOURCE: how do i turn on wi fi for my tablet?
From the home screen press the menu button. Select Settings.
From settings click Wireless and Networks.
You should see the option for enabling Wifi.
After enabling it, you can connect to a network by going into Wi-Fi settings and choosing the applicable network.
Posted on Jun 28, 2011
  • 4 Answers
SOURCE: When I go to use
Do not expose the <a href="http://www.laptopsbatterysupplier.com/4200mah-replacement-laptop-battery-for-a1280-p-2055.html?cPath=9_2163">apple A1280 battery</a> to high heat or freezing temperatures. Do not leave your <a href="http://www.laptopsbatterysupplier.com/4600mah-replacement-laptop-battery-for-a1281-p-2061.html?cPath=9_2202">apple A1281 battery</a>in your car in the summer. Hot <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps8-c-32_2062.html">Sony BPS8 battery</a> discharge very quickly, and cold ones can't create as much power. 6. Fully charge new <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps9-c-32_2063.html">Sony BPS9 battery</a> packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity. 7. For laptops that work as Desktop Replacement, the <a href="http://www.laptopsbatterysupplier.com/toshiba-laptop-battery-pa3534u1bas-c-447_1843.html">Toshiba PA3534U-1BAS battery</a> should be re -installed every 3-4 weeks and allowed to fully discharge. 8. Leaving the <a href=" http://www.laptopsbatterysupplier.com/4400mah-replacement-laptop-battery-for-gateway-nv52-p-1904.html?cPath=35_2094">Gateway Nv52 battery</a> in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Posted on Aug 03, 2011
Ezrahite
  • 2632 Answers
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
Posted on Aug 10, 2011
Will not let me connect to wi-fi it is not my wi-fi servce. it just keeps saying authentication problem
It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
Apr 13, 2015 | Nextbook Premium 8 Se Android
My polaroid tablet model a7 will not authenticate and allow me to go on internet using wi-fi
Try it with a different router. Use a friends. Your router may have to be adjusted.
Go on the manufacturers web site and see if your problem is listed.
Jan 08, 2015 | Polaroid Tablets & eReaders
I can't get no is 9" tablet to work on WiFi. It connects and says connected but won't pull up authentication screen to sign on to network so I'm not able to fully use internet
try turning the wi fi off on the tablet and then turn the wi fi back on and try to reconnect.
you may need to set up the encryption. It could be set on WPA2 and the tablet may not cope with WPA2 may need to use WPA1 on router .
Jan 04, 2015 | Tablets & eReaders
How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
Dec 25, 2014 | Tablets & eReaders
When I try to connect it says authentication problem
It appears that the wi-fi you are attempting top connect with requires an authentication code. If you are connecting at home, it is the passcode for your router. if a business or pay for service system, you will need an account to connect.
Nov 08, 2014 | Tablets & eReaders
How to connect my tablet to wi-fi
Authentication often means "password protection" for the specific wifi connection. Usually your software will present a "dialogue" box telling you a password is necessary and give you an opportunity to enter one.
Jul 31, 2014 | RCA CA 7" Tablet with 4GB eory 28458515
Cant connect to internet
Well, I may be an 18 yr. old and I may be no wiz but I'm big into computers and there are several solutions to this. 1) If there is a password put in the wi-fi, you need to: have a device in which will be able to put in the type of security and/or put in the EXACT password. 2) Make sure it is YOUR wi-fi you're trying to connect to. And 3) If 1 and 2 don't work, contact the company of which your wi-fi was bought from. I hope this explaination was helpful for your problem.
Mar 26, 2014 | Ematic 7" Tablet Computer
Cannot connect my arnova 7d g3 to the internet keeps saying authentication problem. can anyone help
You don't know the password to your wi-fi protected setup. They changed the password when they changed your equipment. Ensure you have the correct password and that you are not too far from the access point.
Jan 20, 2013 | Tablets & eReaders
Tablets & eReaders Logo
338 people viewed this question
Top Mach Speed Tablets & eReaders Experts
BrikimG
Level 1 Expert
David Payne
David Payne
Robert Graf
Are you a Mach Speed Tablet and eReader Expert? Answer questions, earn points and help others
