Question about Kenmore Washing Machines
Does kenmore top loading washer have belt? Purchased 2000
Does not drain completely; I have checked all hoses and removed drain pump//
  • 156 Answers
SOURCE: best way to drain washer to check pump or hoses
broken lid switch usely the call what kind top loader is it
Posted on Feb 27, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore washer
No need to remove the back panel on this model. You can access everything by removing the washer cabinet. Here's how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
NOTE: The washer will NOT operate with the lid switch connector unplugged. If you wish to attempt to test the washer for leaks with the casing removed, you will need to by-pass the lid switch. This can be accomplished by jumpering the two black wires together at the lid switch receptacle. CAUTION: DO NOT attempt to jumper the wires with the washer plugged in! Attach jumper, then plug the washer in.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Now, you stated your washer leaks during the rinse cycle. Double check all hose connections on the water pump (located directly in front under the wash tub). The pumps have also been known to start leaking along the seams. NOTE: If the pump leaks, it is NOT serviceable and must be replaced. They do not come apart.
To re-install washer case:
1. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
I know it seems like a lot, but it is an easy process if you take your time and follow the steps as written. Let me know if you need further assistance.
Posted on May 12, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE3T washer leaking water
The rubber seal is called the "bellow". Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. All three sites offer great service, so shop around for the best prices.
For instructions on how to replace the bellow yourself, follow this link:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair, but it can be a bit intimidating to a beginner. If you have questions along the way, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 31, 2009
  • 50 Answers
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Posted on Jan 08, 2010
  • 1937 Answers
SOURCE: my top load 22922 Kenmore
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11022922100/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Dec 04, 2010
Testimonial: "Thanks so much, oldguy5, for all the information, and links you provided. I felt confident enough to take apart the cabinet myself, & it's working now"
WILL NOT SPIN
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 11, 2011 | Kenmore 15944 Top Load Washer
Washer does not drain completely after use
check the drain hose to see if it is crimped, or loose belt on pump, or something in pump or inbetween the tubs.or obstruction in hose going to drain pump.
Oct 06, 2010 | Maytag MAT12CS Top Load Washer
Kenmore top loading washer will not drain.
Button or coin in the pump
Sock or underwear in the hose
Take your pick
Drop the drain hose into a dish , if the water comes out fast then it is a coin , if the water trickles out it is clothing
Let the machine drain down take the back off disconnect the hose to the pump and check it
MAKE SURE YOU REMOVE THE POWER BEFORE YOU TAKE THE BACK OFF
Feb 15, 2010 | Kenmore 24032\24036 Top Load Washer
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My Kenmore Calypso Elite HD Top Loading washer quit cycling through a complete wash today. I've drained all the water from the interior hoses and found them clean and uncloged. The washer belt looks good...
skipneal,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Check the intake and exit hoses of the recirc pump for debris. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. the hoses to the pump have spring clips holding them on. Be careful taking the hoses off, have something to catch the water from the hoses.
Hope this helps.
-samson39
Jul 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore Series 80 top loader will not drain and begins the spin cycle then shuts down after a few spins depending on the water level. The machine can only be drained manually. There is no blockage of...
There are many issues that can lead to a no drain situation. check the following areas for faults.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 13, 2009 | Kenmore 24032\24036 Top Load Washer
No drain or spin cycle
Check the following to address the issue--
1. Clogged drain line or water pump
2. Water Pump
Jun 03, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer Top Load Series 60 won't drain
The water pump is a belt-driven device actuated by a clutch. Your problem could be:
1. Stuck pulley - break it loose and WD-40 it
2. Broken belt - replace
3. Bad clutch - call repair or replace
There is almost nothing that can go wrong in the pump itself. It's probably one of these three.
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
My Kenmore 80 top loader washer is full of water and will not drain. Yesterday I tried to speed the cycle along and stop it during rinse cycle and moved it forward but now I have tried everything and it...
Sounds like the drive belt that operates the pump has failed.
You will have to pull the washer out and remove the back panel to peer inside. The pumps are normally a piece of **** plastic and about the diameter of a 'personal pizza' and are driven by a V-belt when working. You should also be able to see that one of its hoses goes to the rear of the machine and exits to the drain pipe.
If you find you do need a belt, you can get the proper part number from the online Sears/Parts section by entering your complete model number when asked.
The pumps don't normally quit instantly but start to leak on the floor if the seals fail so it is likely only the belt.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore agitates, but no spin or drain
Your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley you should remove the pump from the washer and try to rotate its pulley manually. If it doesn't turn freely(frozen or stiff) it should be replaced. In case of a broken pump's belt or belt looks quite worn, replace it. In any case,check the pump's pulley before you replacing the belt. Good luck !
Aug 16, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
