Question about Whirlpool Duet GHW9150P Front Load Washer
How to remove bottom plate on the ghw9150p - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 17,130 Answers
Please check for tips from this video link
removing back plate
Posted on Dec 31, 2012
No drain and spin
Remove the front bottom kick plate and clean the filter.
Mar 02, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Error code sd
SD is a slow drain condition. Remove the bottom front kick plate and clean out the filter. Have a bunch of towels at the ready!
Dec 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain
Remove the 2 screws that hold the bottom front kick-plate on and remove the plate. Then, on the lower right hand side you will see a filter on the drain pump. Remove the filter and clean it out. Have some towels handy! There will be some water that will come out!
Jan 19, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Where is the kick plate and how do I remove it?
The kick plate is the piece at the bottom front of the washer. The kick plate is often attached by friction fastener and is removed by prying it off
Dec 20, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont drain
Remove the bottom kick plate and clean the filter.
Nov 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F02 error on whirlpool front load washer. How do you open the kick panel?
Depending upon what model you have, most kick plates are removed by taking the 3 or 4 (1/4 inch or torque) screws out located underneath the kick plate. Note that not all front load washers have a kick plate so be sure that there is a prominent gap between the upper most region and the small lower region being the kick plate.
Apr 22, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Getting an error message on my Whirlpool duet washer - F21
F 21 means slow drain remove lower kick plate couples screws at bottom//you will see the drain pump there is a clean out at the front of pump/ turn that out counter clock wise that is a coin collector but many other objects get in it to/ remove items and reverse to put unit back together....
If I helped you please vote If you need more help please ask good luck
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer whirpool
Hi smokebear,
You most likely have a blocked pump. remove the front bottom panel from the washer. You will need some torx bits screwdriver to remove this. When you remove the plate you will see your pump right in front of you. It has a large removeable filter that you can clean out. Be careful, water will come out when the filter is unscrewed so have a pan or towels ready to catch it. You will probably have 3 or more gallons come out. Unscrew it slowly and catch the water then tighten back up untill all the water is gone. Good luck to you and I hope this will FixYa.
Mike
Aug 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet: "remove the heater..."
don't know the whirpool duet cos i'm in uk not us.
i assume your machine is a front loader
places to look for heater are
remove back plate and look for heater at bottom of rear face of tub
sometimes heater is mounted on front plate of tub in which case tilt machine backwards and see if you can see heater mounted towards bottom of front face.
most likely place however is on the rear plate of the tub
Jul 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dront loader washer
you will have to remove kick plate to locate service info located at bottom.this should tell you what code means.
Jun 19, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
