Question about Refrigerators
Refrigerator maytag modle# mbf2256kew
Fridge is not getting cool freezer is still frozen
  • 2039 Answers
SOURCE: Maytag S/S model # MSD2756GEB
di you see or hear the fan running fan might be stuck check that out no fan no circulating cold air you may have problem with the heating element what make frost free inside you should melt all the ice inside around the damper check if you see broken glass the little heating element if it not broken and listen for that important fan if it running check it uot thank for using fixya pierre
Posted on Feb 05, 2008
mikedurland
  • 481 Answers
SOURCE: maytag refrigerator clicking
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 06, 2008
SOURCE: My Beaumark Bottom Freezer Refrigerator Doesn't Work
problem is probably that the evaporator is frozen up preventing circulation of air and the fan is jammed with ice.
remove the back panel inside the freezer. melt off the ice with a hairdryer taking care not to heat up any stats mounted on the pipework.
appliance will now work but this is a temporary repair. you must find out the cause of the ice build-up ie why not defrosting.
for starters, check the defrost heater and the thermal cut-out inseries with it.
let me know how you get on and what you find. make sure the fan is free to rotate.
tresilla
Posted on Nov 06, 2008
  • 19 Answers
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
  • 4 Answers
SOURCE: Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Posted on Apr 19, 2009
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
The freezer keeps things frozen, but not 100% & the fridge is not cooling at all
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 24, 2011 | Maytag MFD2560HES Bottom Freezer French...
TZ21QL MODLE REFRIGERATAOR WILL NOT COOL ON ABUOT
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Amana ATB1832AR Top Freezer Refrigerator
FREEZER FROZEN, REFRIGERATOR WARM
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 13, 2010 | Maytag MSD2454G Side by Side Refrigerator
Hi , i have a Z sidie by side maytag fridge/freezer my fridge section is freezing up even though the setting is now on 2.but the numbers are flickering,for both freezer and fridge compartments. l...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Maytag Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
