True Direct Draw Systems: Kegerator TDD-3 Logo
aaronhyatt Posted on Dec 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do true kegerator parts have to be replaced with true parts
Joe Palazola
Level 2:
Novelist:
  • Expert 124 Answers
  • Posted on Oct 24, 2013
Joe Palazola
Expert
Level 2:
Novelist:
Answers
124
Questions
Helped
85821
Points
178
Depends on what part you are looking for. I use condenser motors, evaporator motors, thermostats, and even compressors and capillary tubes that I sometimes get at local suppliers. If you're looking for gaskets, hinges, panels, tap heads or something like that it may be easier to get from True.
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Replacing true kegerator parts
no use a Ranco p# A12-700 make sure the capillary is in the coilto sense the temp and set it to 1.5 on the knob. any colder and it could get too cold . you may be able to set it at 2 but be careful. it is a constant cut in at 37 degrees coil temp. the box temp will drop to usually to 28 or 29 at cut out.
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
Where can I receive a parts list online for a True GDM-12F Freezer
1 800 325 6152 is the True factory tech assistance number. They will be glad to help.
2helpful
2answers
Do you know where I can get the defrost heat element for a True freezer T-49, in Dallas, Tx.
Try refrigeration hardware service out of Colorado. I'm not sure they sell to the end user, give them a try.
Frigidaire chest frezer kegerator conversion
The cabinet is the condensor. The lines run all around it. Unless you add an external condensor kit, the only safe place for holes is the door.
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
