Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
12 volts plug in for my TV
Hi , I purchased a Sanyo TV CLT2054 and I want to use it in my RV (motorhome) which runs on 12 volts when I am on the road without utility. So I would like to have a gadget which plugs in the cigarette lighter (12 volts ) to run my TV , without going through the step down power supply. Any body knows where I could find either the whole 12 volts plug-in or the parts to make a plug-in without going throught the sept down transformer. thanks
  • Luc Tremblay Jun 24, 2007
    thanks a lot, but this is exactly what I did not want to go throught the power inverter, since this TV work directly on 12 volts.
    After discussing with a local tech, I decided to cut the power line and installed two quick plugs on the line and used a cigarette lighter plug in ,,, it's working fine in the RV (12volts)....or in the house (on the power supply 110v).
    again thanks for the info.
  • Anonymous Mar 19, 2014
    Do smart TVS use 220 volts default? Which TV models can be used in other countries without a transformer ?
    President:
  • 1,314 Answers
Sure. These are called power inverters. Here's a link to one that should work. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=422932&CatId=237 Make sure you look at the wattage rating of the electronics you wish to run on the inverter and make sure you don't exceed that wattage rating on the inverter. You can get larger inverters but they have to be usually hardwired into the battery system of your vehicle.
Posted on Jun 23, 2007
  • Kevin Shafer
    Kevin Shafer Jun 25, 2007
    My apologies for misunderstanding your question.
    Yes, the lighter plug in would certainly do the trick :c)
Where does the 12 volt dc power for the roof a/c come from
comes from your 12 volt battery that is installed in your RV/ Motorhome, which also runs some of your lights in the RV/Motorhome too.
Jun 19, 2010 | Dometic Rooftop RV Air Conditioner
My Sanyo TV just quit working one day after a bad electical storm Its a Model number CLT2054 with an external 12 volt AC to DC converter cord. I thought it may be the converter and replaced it via the...
Did you bought your replacement AC Adapter on Ebay. well I bought mine on Ebay as well but you know what they're not the exact replacement. I encountered a problem with mine, because of the reverse polarity on the output power. you can fix this though, cut the output wire leading to your TV then connect the white wire with the un-shielded one and to the same on the other wire.
Sep 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo CLT2054 - power cord has light but when I plug it into the
OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
SANYO CLT2054 WITH FADING SCREEN
We had the same problem and it was the ac adaptor which is next to impossible to find. If you find one let me know where?
Jan 27, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Screen went black
Check the power supply for 12 volts dc, it must provide at minimum 3 amps of power to trigger the on circuit. If not, replace the adapter... if you need one, please contact me.
Jan 12, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
I have a CLT2054 but i missed the power cable
I bought one on Ebay and it didn't work because the one they sale on Ebay has a reverse polarity, try fixing this, cut the output wire, the one leading to your TV, then reverse the connection, white to un-shielded wire and do the same on the remaining wire.
Aug 22, 2007 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
206 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
