Question about byD sign 3032 30 in. HD-Ready LCD Television
My blue light on myBYD:sign 3032 light does not come on and fan on Power adapter does not come on
5 Suggested Answers
  • 3 Answers
SOURCE: Power Adapter
I have a new OEM power supply for this tv.
If interested, email me your contact info.
Thanks,
Art
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: peascorn
I have a New OEM power supply for a byDesign 3032 TV.
If interested, please email me your contact info.
Thanks,
Art
  • 3 Answers
SOURCE: Power supply for byD:sign 3032
If intertested, please email me your contact info.
Thanks,
Art
  • 5342 Answers
SOURCE: The picture on my BYD:sign 3032 has been going out, sound is OK
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Jul 08, 2010
Testimonial: "Thanks for the detailed explanation and diagnosis!"
Need power cord for d:3032 by d:sign tv
It can be bought from most of the electronics spare part selling shops.
Jun 11, 2015 | Televison & Video
Keyboard quit working; blue charge light on
faulty power adapter port, may have blue light meaning charger is working normally, double check with another working power adapter or use your adapter with another keyboard to check which device has problem, power adapter or keyboard port.
Oct 12, 2014 | Targus 90W AC Universal Wall Power Adapter...
I need a power cord for a BYD LCD tv model D:3032
Power cords can be bought from most of the electronics spare part selling shops at your town. There is no special attention to choose one. Select a good quality power cord from a reputed brand. that is all.
Jul 03, 2012 | byD sign 3032 30 in. HD-Ready LCD...
Hp compaq 7620s wont start ( constant blinking blue light )
The adapter output appears correct, the batteries often work in that voltage range. But the problem you have is the motherboard, the HP line has constant trouble with the main board, only option is board replacement.
May 12, 2012 | Computers & Internet
Blue power light comes on, no fan, does not boot
Some adapters have fuses. U may have to replace the fuse :)
Jun 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Thanks,
Art
Aug 25, 2008 | byD sign 3032 30 in. HD-Ready LCD...
Peascorn
Thanks,
Art
Jul 17, 2008 | byD sign 3032 30 in. HD-Ready LCD...
Power Adapter
I NEED a new power adapter ttttttttttoo.. can you HELP please,, I allready had a so called TV repaire Man try to fix it he said he cant get a new power adapter for it to be fixed .... I stupidly PAYED him waited 9 months later, and still no TV fixed..Im taking him to smalls claimes court.....Very un happy persone ,I just want a new power adapter,....please some one out there...peascorn...I have d:sign TV 3032- ad-13d-2...
May 25, 2008 | byD sign 3032 30 in. HD-Ready LCD...
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
byD sign 3032 30 in. HD-Ready LCD Television Logo
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
