Question about Nikon COOLPIX S220 Digital Camera
Need to retrieve pictures from Nikon S220 that are not on memory stick but show up when memory stick is removed
Pictures were accidentally taken with memory stick out of camera. Great shots of our grandson but unable to get them from WHEREVER they are in my camera. Please help me! They disappeared when I put memory stick in......thought I'd lost them. When memory stick removed, I was able to see them again as I went back through pictures as I would with stick in.
    Sergeant:
  • 321 Answers
Data recovery software
Posted on Jan 11, 2013
otacon
  • 1944 Answers
SOURCE: Lost Pictures
Try using this to recover the lost pictures.
www.recuva.com
Posted on Mar 25, 2008
Agent Allan
  • 480 Answers
SOURCE: Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 11, 2008
  • 4 Answers
SOURCE: sd memory card cannot be used
This happenes when you remove the card while read/write process is still going on. Try some professional service who will retive the data for you from the mem card. Hope this helps.
Posted on Jan 19, 2009
Steve5
  • 423 Answers
SOURCE: I have the Nikon D60 - Ive taken sport/action pictures
The main difference between the two shooting conditions is the amount of light you have to work with. For the indoor action shots, set the ISO setting to the highest available through the menu (1600 ISO) to maximize the ability of the camera to work with the diminished light. The other (but more expensive) way to achieve better indoor shots is with the use of a "faster" lens, ie one with a lower maximum f stop number (f2.8 is faster than f3.5, for instance). Also ensure you are shooting with your lens at its widest f stop setting (lowest number).
Posted on Jul 26, 2009
  • 11967 Answers
SOURCE: nikon d60 won't play back pictures
Sounds like your computer or the software program you're using to download your pics is set to automatically erase the card after the download.
Posted on Aug 15, 2009
I have a S9100 Coolpix camera and all pictures have been erased. Is there any way I can retrieve them?
You can try camera photo recovery software like asoftech photo recovery, you can refer to this tutorial
Recover Pictures from Digital Camera
Hope this helps.
Sep 10, 2012 | Nikon Coolpix S9100 S-9100 26248 Black Hd...
Took pictures without memory card Nikon D3000 camera, can I retrieve them?
No. Without a memory card the camera stores the last picture taken only so you can view it to verify proper operation. It overwrites the previous picture, and it disappears when you turn the camera off.
You NEED a memory card if you want to save the pictures. Sorry if that wasn't the answer you wanted to see, but that's the way the camera works.
Jul 28, 2012 | Nikon Photography
Nikon s220 says file contains no image data when I try to review my pictures. They do show up on my computer when I put in my memory card.
When you remove your card from the computer, do you remember to use the "safely remove hardware" function? If not, you risk corrupting the card which is what probably happened.
Oct 31, 2011 | Nikon COOLPIX S220 Digital Camera
S220 Wont upload pics to mac, do i need cd?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Feb 11, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Can't transfer pictures to computer
Found solution thru a google search, unplugged the camera from the computer, turned the camera off, plugged it back in and then turned it back on, the camera icon finally showed up in the Nikon transfer program
Jan 28, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
I JUST GOT THE NIKON S220 TRIED TO DOWN LOAD THE SYSTEM TO TRANSFER PICS TO MY COMPUTER. I GET A NOTICE THAT I DID IT , BUT DO NOT GET THE SCREEN THAT SAYS TRANSFER COPY PICTURES TO A FOLDER... I DID...
Are you removing your memory stick and then placing it into a port on your computer, or do you plug a cable in to your camera? Either way, it should work.
If cable: (camera OFF) plug both ends of cable to their respective ports, then turn camera on. Windows should then detect the camera, (and maybe install drivers for it {"Found New Device"}), and then you should get the "your device is installed" window. If you don't get the "Copy your pictures" window, you may need to turn it off, wait a few seconds, and then power it back on before that happens.
If memory stick: Windows should detect your memory stick, again maybe it will need to install drivers,unplug, wait a few seconds, return it to the memory stick port.
Also, sometimes your product will come with it's own CD or DVD with download instructions or manuals, apps, etc., on it.
Hope this helps!
hansola
Nov 06, 2009 | Nikon Coolpix 2200 Digital Camera
How to upload pictures from a Nikon coolpix to a dell computer
download your s220 nikon driver here...
http://support.nikontech.com/app/answers/detail/a_id/61
IMPORTANT to install the software before pluging in the camera!!!
But my ideal solution to downloading pictures is to remove you storage media from the carmera and use a card reader...
doesn't waste batteries, much quicker, needs no software to work...
please leave feedback if helpful
Oct 25, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Camera does not show taken ( saved) pictures
problem is in memory card...i think. try with cleaning memory card contacts. use pure alcohol and small piece of cotton to clean dust or other dirt. if this not help, try some card reader to transfer images from camera to PC. try also with some other camera. it's possible memory card is damaged and you can't do nothing. try reinstall nikon software on your PC.
Feb 19, 2009 | Nikon Coolpix L15 Digital Camera
Retrieval of Pictures taken without a memory card
If you remove memory card your camera will show the pictures held in his internal 27 megs memory, as if it was memory card. Same if you connect to computer with no memory card inside.
This is all.
Apr 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Nikon COOLPIX S220 Digital Camera Logo
26 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
