Question about Samsung S1050 Digital Camera
When I view my pics on camera, I cannot view back (left)
When I try to view back a microphone looking symbol and the work Start: Shutter appear. How can I get rid of this. It says nothing in the manual.
Please help, thank you
Janet
when you are view your pictures you have taken you are hitting the little movie camera button which is at the top of where you are pressing the arrow back and forth. just hit that button again and the
microphone will go away. I have had this happen to me. the button are small and our fingers are to big. once the microphone goes off you will be able to push the arrows to view your pictures forward
and backwards.
hope i have helped you
connie
Posted on Feb 15, 2009
When trying to take a pic, a red camera symbol with two curve at both sides at the bottom of the camera symbol appears...this comes up in bottom left hand corner. Please help. Thank you, Robin
Sounds like the warning of low shutter speed end therefore the tanger to get "hanshake" blur captured. Use flash if possible or highter ISO setting or steady hands ;)
Mar 11, 2015 | Canon Powershot A2000 IS Digital Camera
What does a yellow camera symbol indicate on the screen please
does it have an exclamation point? If it does, it telling you (slow shutter speed).. use the flash or mount it on a tripod when taking pics
Aug 12, 2012 | FUJIFILM Cameras
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
When turned on just shows black screen. Used to be able to pwer off and back on and would work. Lens issue? Can view pics on memory card just can't take pics anymore.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 14, 2011 | Canon PowerShot S2 IS Digital Camera
I am on vacation, so no book. I have a nikon d7000 and i want to set a timer to take pictures of my hubby and i. Can u help me?
Press the release mode dial lock and turn the release mode to the one-handed clock symbol. Press the shutter release button to start the self-timer.
If you want to change the length of the self-timer delay, it's the Custom Setting #c3.
The release mode dial is on the top left of the camera (as viewed from the back). The lock is just below and left of the dial.
You can view/download the manual at
http://support.nikonusa.com/app/answers/detail/a_id/17008
Sep 09, 2011 | Nikon D7000 Digital Camera
I just put new batteries in my N65. I haven't used it in a while but it appeears to be working proper, ie the lcd comes on and indicates full battery and the view finder symbols are nice and bright green...
What I'm thinking is the shutter and or the aperture ring is lazy. Move the aperture ring up and down several time see if the little ring next to the the camera body is responding quickly to the change.
Do this without film in the camera.
What I'd suggest is setting the camera in "M" mode aperture at F8 manual set the ISO at 100 and the shutter speed at 1/60 shift the camera into manual focus. The shutter can be in AF-S (single frame with each depress of the shutter). Trip the shutter and listen to it work do that a few times (maybe three) then set the speed at 1/125 do the same test listen the shutter should sound faster. Repeat the test at 250 then 500 then 1000. Then start backing down to 1/60th again, listen to the response. In all manual mode the shutter has to fire it it isn't or the speed doesn't increase and then decrease then the shutter needs service.
Jan 14, 2011 | Nikon N65 35mm SLR Camera
When I take a pic all I get is bright light
Sounds like your lens shutter is not closing. This results in very bright pictures(overexposure). I suppose it could be a shutter speed setting. Look around in the camera setup menu for a "camera reset" or "initialize" command.
Nov 13, 2008 | Samsung Digimax D53 Digital Camera
Camra dosent show pic
Please see similar problem titled "black screen". Welsbar posted a possible solution as a clarification request. It involves switching your picture mode to TV and changing the shutter speed to 15 seconds, depressing the shutter button for 7 seconds, then opening battery enclosure. Repeat as necessary - I did this twice before I started to see anything on the screen. Twice more before photos start to look okay. Don't know yet if this is a lasting solution, but at least now I can start using the camera again and find out!
According to Welsbar, the problem is an internal part (iris?) that gets stuck when camera hasn't been used frequently.
Nov 04, 2008 | Canon PowerShot S2 IS Digital Camera
Won't take a picture
I work on these cameras all the time you have a ccd going out or has gone out that is causing the auto sensing feature to now work their for the camera stops working. 1 other thing it might be could be the main-board but they don't go out as often.
Mar 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Blurred pics / Shutter speed on Fuji A470
Hello
The hand symbol is alerting you that the camera will have to use a slow shutter speed to get enough light into the camera. Try pointing the camera at something bright, and the hand will not show. Therefore, if the hand is on, then you probably need to use the flash.
Jan 09, 2008 | Cameras
Samsung S1050 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
