Question about Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump...
Suddenly whirlpool action in jacuzzi tub very low
Pump works . Screen in tub is clean. Could be the air function has something to do with it. Is there a screen under the tub for the air supply that could be clogged or is there a separate air blower aside from the water pump that may not be functioning?
    Problem Solver:
  • 19 Answers
Try turning the jets clockwise while they are running and see if this makes a difference.
Posted on Feb 03, 2009
Is it possible to buy somewhere the Optional "U-Frame Skirt" for a "Jacuzzi CIVA Whirlpool" bath tub? Anyone know where or other suggestions on covering the front?
Home Deport and Lowes each used to carry a generic front skirt for "jacuzzi" type tubs. You may find something at one of their stores that will work.
The other solution would be to contact a Jacuzzi Showroom for authorized replacement parts.
Dec 02, 2014 | Jacuzzi Home
Aqualux whirlpool tub how do I clean jets?
Try and blow the lines out with air, sounds like something is stuffing the water jet. Drain system and turn off power first.
Nov 02, 2012 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi tub air push swith not hooked up
It does hook up to the pump/motor there should be a friction fitting that the hose fitts over there is a square like box sitting on top of motor this is where i would look for the hook up (should be in the area of the pump/motor electrical cord) . I hope this helps. Thanks for using FIXYA. Have a great week.
Apr 05, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi hot tub model J-300 series with an FL-1 code. I have shut off power at box and restarted a couple of times and the circulation pump reset. Now the reset won't happen. Both pumps still operate and I...
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Jan 06, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
Whirlpool tub not cutting off.
First I would remove the switch hose from the pump. Pinch the end of the hose over and hold it in place with a piece of tape. Depress the button and hold. If the button has little to no resistance then there is a hole in the air line which is causing enough air to leak that there is not enough force to activate the switch. If that is not the problem then just consider leaving the switch in the hole on the tub surface but adding a regular wall swich to the wall near the tub. This move the switch action from the tub to the wall. This a really cheap solution compared to getting a new switch mechanism which is what is broken for about $200.
May 23, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Bath tub spa will not shut off
If you haven't done this already. I would search your breaker panel for a circut breaker titled jacuzzi tub (or something to that effect), and if it is not listed I would get someone to monitor when the tub shuts off, while you flip each breaker off, one at a time so as to determine which breaker it is and then immediately title it.
Next, an access panel to the tubs motor should be installed. After access is gained, inspect the pumps receptacle and if it is not GFIC protected I would return to the breaker panel, it may have a GFIC breaker. If neither are the case, then have this issue repaired
The button on your jacuzzi is air actuated with a flexible air line that connects to the actual switch, it may have broken or however became disconnected.
Any questions, feel free... Good luck...
Feb 21, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
My jacuzzi stopped turning on.
I would check all power to the tub. Is it plugged straight to a breaker, plugged into a GFCI, GFCI breaker in the master panel? For it to just stop altogether I would think something tripped.
Oct 21, 2008 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Logo
172 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
