Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Rheemglas water heater leakage from the top seal
This is 220 litter mains pressur rheeemglas water heater leakage from the seal at the top side
  • Rheem Master
  • 5,245 Answers
1) You have leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
2) I do not know what is meant by 'top seal' since that is not typical water heater part.
Does you product manual show a top seal?
Add comment and describe the top seal and add what it does.
3) Attach a photo.
Posted on Dec 31, 2012
  • 92 Answers
SOURCE: flush Rheemglas Fury 22VR75 yearly-increase life of H2O heater?
yes you will increase life if you flush sediment yearly
Posted on Apr 16, 2009
kirkx
  • 2019 Answers
SOURCE: There is water leakage from the top of the water
It is rare for water heaters to rust out on top, so I would assume it instead was a loose input, output, or anode. With water and gas or electricity off, disconnect the input, output, and remove anode rod.
Seal with teflon tape and replace. If the anode looks corroded, then replace it.
http://www.plumbingstore.com/sacrificial_rods.html
Posted on Feb 28, 2011
  • 126 Answers
SOURCE: I have a 12 gallon
turn off the power,then on the side of the WH there should be a Blue cover take the cover off,if u have gloves u might want to use them because u might have to move a small section of fiberglass out of the way after that u will see a black looking box with a red button in the center below that button on most WH u will find the thermostat use a small screw driver to turn it down Clockwise to turn it up Counter clockwise to turn it down Put fiberglass back in put cover on turn power back on
Posted on Mar 31, 2011
SOURCE: rheemglas fury model # 41V50
I have a 50 gl rheem the pilot it doesn't stay lite.
Posted on Jul 21, 2011
SOURCE: which one is compatable water heater to Rheemglas
You have 6-year 50 gallon gas water heater:
42V50 would be the newer model number. They make tall and short models.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
All brands of water heater are good.
So any 50 gallon gas water heater from local box store or hardware is good product.
Tanks with longer warranty last longer. So 9-year and 12-year water heater will last longer, unless you have very hard water or odor in water and need to change frequently.
I recommend avoiding water heaters with electronic controls since they are not protected from power surge and can cost more to repair.
Additional resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 31, 2011
I have a Rheemglas 130 litre gas storage system. Does anyone know where the anode is placed as the unit is covered in foam?
Usually inserted from the top. There is a threaded piece, to which it is either attached, or by which it is held in place. The isolation valve will need to be shut off, or, lacking one of those, shut off the house water main. A tool that applies vibration and torque simultaneously will be needed to free it. ALL WATER IN THE HOME, THAT IS ABOVE THE WATER HEATER, MAY DRAIN SLOWLY THROUGH THE OPENING, WHILE YOU ARE CHANGING IT OUT. Therefore you must have the replacement on hand. If there is visible rust around the nut you will be loosening, there is a chance you will have to replace the heater. Good luck!
Mar 29, 2017 | Water Heaters
Corroding top of rheemglas 21vr50-2t
Corrosion caused by condensed acidic water dripping down vent pipe, bad venting pushing acidic combustion by-product out of vent hood, trace chemicals stored in same room as water heater, dielectric corrosion because water pipes not grounded, hot water pipe above tank is not insulated and condensation dripping down on top of tank ... are things that come to mind.
Test venting:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#vent
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Mar 26, 2013 | Rheem Water Heaters
Water drips from the overflow pipe on top of the electric hot water tank Tank is a RheemGlas
1) Copy following link for troubleshoot and replacement:
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Add comment Mar 2013 and say what you discover
Mar 11, 2013 | Water Heaters
I have a Park Model RV with a Rheemglas Fury model 81VP205 with no bottom drain. How do I drain the water heater to winterize for the cold Northern Winters?
Make sure it's off (hydro) and open drain at cold line going in bottom wherever you find a drain (usually close to it) going down through floor and outside under trailer. Follow cold line back until you see a line "T" and one line going down under trailer, and open it up underneath. Then open pressure relief valve at top of tank to allow for faster draining .
Oct 14, 2011 | Water Heaters
There is water leakage from the top of the water heater
Feb 28, 2011 | Rheem Water Heaters
The water leaked out overnight. We have not tried to start it again as it is still dripping water. We have a rheemglas Fury Model # 22-40 natural gas.
Open following link to troubleshoot cause and solutions for leaking water heater:
Rusted water heater must be replaced.
For money-saving water heater information:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a 21v40-7 rheemglas waterheater that is leaking from the line where the blue cap and the white water heater meets why is this happening?
If you see water at the top of the water heater you should take a rag and dry everything well, you should be able to see where the leak is from, if it leaks from the metal "housing" up you probably need a new water heater
Jun 28, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Rheemglas 50 gal electric water heater. It is 6 years old. It has always worked fine without any issues. I recently drained it and refilled it. I notice from time to time that water is draining...
Hello, It sounds like your T & P relief valve is leaking and needs to be replaced. Over the years, corrosion prevents the valve from sealing properly if it's been opened. It is usually threaded into the top or upper side of the water heater with a pvc pipe attached to it for drainage. If you want to replace this valve, you can buy it at any hardware or home improvement store. Turn off the cold water shutoff valve on the top of the water heater and open the lever on the T & P valve to let it drain out the water. When the water level reaches below the T & P valve, it will stop draining. Then disassemble the pvc pipe if it's threaded, or if it's glued, cut off a section or fitting and replace it with a new one when you reassemble it. Use teflon tape to seal the threads on the new T & P valve. Wrap it around the threads 3-4 times in a clockwise direction with the threads pointed at you. To remove the T & P valve, you can use a 3/4" x 6" black iron or galvanized nipple as a leverage tool to untwist the valve from the water heater. Turn the cold water back on and make sure your thread seal is holding before filling it up all the way. Good luck! Douglas
Jun 27, 2010 | Water Heaters
A2 error on Bosch tankless water heater
  1. Check continuity of the flue gas limiter (see Fig. 63, page 46 of manual). Go to steps two and three to determine air box temperature sensor fault and replace it.
  2. Check for flue gas leakage around the top and bottom seals of heat exchanger as well as the viewing window.
  3. Check that venting is within specifications (see Section 3.3 of manual). Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure.
  4. Check that flue gas limiter connector and spade connections are secure.
  5. Unplug heater and check the two main plug connections inside the control board.
Jan 22, 2009 | Bosch & Tankless LP Hot Water Heater
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
