YOU ARE NOT HELPING ME!! I"M GOING ELSWARE!!
You are not helping me and i am tired of YOU!
I have a 99 expedition I had the tires changed I put smaller tires on it to get rid of the mud tires now my front end shakes like it has 2 flats
more than likely there is some component damage ,linkages, tire rod ends, vibration dampener the shock looking thing under front end , connecting left to right on steering link.
Feb 22, 2015 | 1999 Ford Expedition
How do I line up my rear tire on my 1978 GS Suzki ,I just had to fix a flat on the tire
There is a ruler / notched washer and marker on the frame on both sides of the axle, as long as both are adjusted (adjusters on the axle with locking nuts) the same job done.
Oct 02, 2014 | Motorcycles
Acer c7 chromebook manual
A little Googling and you would find your answer...
http://www.samsung.com/us/support/register/product
Maybe readers are tired of lazy people criticizing others who actually put some effort into helping.
Jan 11, 2014 | Acer Computers & Internet
07 ford escape has a bad vibration or shaking at 60 mph ?
Did they check the universal joints in the driveshafts, and the slip yolks. That will cause a vibration at certain speeds.A bad Constant Velosity joint in the driveshaft will cause another vibration sometimes worse that a u-joint. Have someone that knows about drivelines check them and you may solve the problem. I hope i have been of some assistance in helping you resolve the issue.
Apr 02, 2013 | 2007 Ford Escape
Why does my service 4 wheeldrive light come on on 99 gmc yukon
I would start by making sure the tire pressure in all the tires are the same and that the tread on the tires have the same amount of tread left. If they are just a little off the Service 4WD light will come on and most of the time that is the problem. Once all 4 tires are equal in pressure and tread wear, it may take a few times of starting, driving around, and shutting the engine off for the light to turn itself off and realize the problem is corrected. Hope this helps but if not, reply and I will keep helping until the problem is fixed.
Nov 08, 2011 | 1999 GMC Yukon Denali
What type of tires would you recommend for winter driving?
latitude-x-ice.jpg Latitude® X-Ice®
Winter
Winter Tires
Better Starting Grip in Icy Conditions.
A special Winter Flex Compound, specially formulated to maintain its grip under the most extreme cold-weather conditions, including snow and ice, to help deliver better starting grip and shorter stopping distances.
Better Traction In All Winter Conditions
Cross Z-Sipes Technology uses a specially designed curve that locks the sipes in place, helping to provide improved grip on snow and ice. And because the sipes are full-depth, their grip lasts winter after winter.
Quiet, Smooth Ride in Cold-Weather Conditions
Dec 02, 2010 | 1996 Jeep Grand Cherokee
Blurry webcam
There is a dial around the eye of the cam.
Turn it to focus.
Please gave a vote (Rate our solution), it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Apr 01, 2010 | Logitech Quickcam Chat Webcam
My shower is run off a combi boiler and recently started to go cold for a couple of seconds every few minutes and nobody is running water elsware in the house.
Check the hot water flow at the shower - if it's as good as other taps the boiler diverter valve is suspect. Replace either the complete valve or the internal rubber diaphragm, depending on the boiler make
Mar 29, 2010 | Home
When i put opn the breaks my van shimmeys like
Although "Rotors" would have been a good guess, the wheel bearings, ball joint and tie rods should all have been checked after the wheels were lifted off the ground. Also the Caliper Bolts and/or Bolt Guides should be checked to see if they are warped. Warpage could also cause shuddering.
Is there any shaking while at highway speeds (without the braking)? Then it could be an alignment issue.
A bald tire in the front is not helping matters...it is dangerous and illegal in most states. The small dent in the rim in the back is not safe either. This could lead to a catastrophic tire failure. You can hammer those back a little and make it safer.
Good luck!!
Nov 17, 2009 | 1996 Dodge Caravan
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
