How do I get the camera to work its built in
SOURCE: built in webcamera driver for msi u100
Hello.
Your problem is not the drivers. The msi u100 webcam is supported by the operating system without the need for installing drivers for it.
Instead, turn it on by pressing and holding the Fn key (bottom left corner) and then pressing F6.
Cheers
SOURCE: msi virtual built-in camera lost and im using
1. if the problem happened recently try to do a system restore to go back previous to when the problem started.
2. check device manager, find if there's any ? or ! yellow marks next to what looks like your camera, open the properties of the device (if it's showing) and post back with the status info, , you may need to reinstall the driver or update it. post back with our model number
SOURCE: MSI U100 :S
I believe holding down the Fn button (on the bottom left of the keyboard) and F6 turns the webcam off and on. If it is off, it won't be seen by windows at all. Just hit Fn and F6 at the same time and you should be all set. The F6 key even has a small picture of what should be a webcam.
EJ
SOURCE: how to activate the builtin web camera on my MSI laptop
Press the blue "Fn" button on the lower left hand side. Then as your holding that button down...press "F6". There should be a small webcam icon on this button. This worked for me so I hope this helped!
SOURCE: touchpad on msi a6200 not
Reinstalling the driver by going into http://us.msi.com/ should fix it. if not touchpad is broken and needs to be replaced
