I need a diagram and schematic to help walk my daughter through cleaning the filter on a Hot Point Ultima Extra WDM73 1200 Spin washer dryer, can you get me one?
E15 is showing up on the read out which means probably that the filter is plugged. I need diagrams and schematics so I can walk my daughter through te process, can you get them for me?
  • Washing Mach... Master
  • 17,130 Answers
You can get some tips from the following link
Washing machine tips.
Video assist
Posted on Dec 31, 2012
5 Suggested Answers
SOURCE: E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Posted on Oct 17, 2010
SOURCE: Hotpoint ultima extra washer dryer WDM73
i found this manual,if you know what your problem is this might show how to change the faulty bit. I dont know what machine this is but they all seem pretty simular, i used this to change my door lock.
Posted on Jun 16, 2008
  • 1417 Answers
SOURCE: my hotpoint ultima extra washing
hello,
what e15 indicate means an error code that there have been an over flow of water from the drum over to the panel or the wire that suppl power to the screen .
what you will have to do to fix up this problem from the screen is to unscrew the screws with screw driver care then trace the wire ,that is the power supply down to the panel and also to the screen clean up all forms of liquid around the wires and also the panel carefully . then couple it back with care to is position with this the problem is solve.
thank you.
Posted on Aug 07, 2010
richroth
  • 9472 Answers
SOURCE: e30 error message received for my WD72P HOT POINT ULTIMA EXTRA WASHER/DRYER
E30 means the motor isn't working on this machine. There used to be a 7.5 amp fuse on the power modules on these micro processor controlled washing machines which used to blow if the motor went faulty.
It could be that the brushes have worn out and the motor has blown the fuse. This can happen if they spark excessively but it can also happen if the armature goes down to earth, or the armature is faulty. You really need to test the insulation of the motor though with a specialist meter (megger)
Posted on Nov 22, 2012
My hotpoint ultima dryer has no power to it changed fuse checked plug socket emptied water tank cleaned both filters
power comes in at mains lead goes to the choke /filter from here onto the door interlock switch then onto timer ......hope this helps
Feb 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
Dec 20, 2009 | Hotpoint Washing Machines
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Need to find the filter as drum not spinning and water leaking
The filter on this model is in the main hose leading from drum to pump. It can be accessed by removing the panel at back of machine.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Error E15 - MAchine not draining
drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Nov 10, 2006 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
