Question about Numark ttUSB Turntable
Numark ez converter software stops recording after 1 min
    Guru:
  • 417 Answers
You must have set a marker on the rec track
Posted on Nov 04, 2013
3 Suggested Answers
  • 104 Answers
SOURCE: Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Posted on Feb 11, 2009
  • 691 Answers
SOURCE: Received a Numark TT usb
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Posted on Jul 31, 2011
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
Ez audio convertor stops recording after 1 min
You are using a trial version. Unless you pay for the full version you only will get one minute. If you have paid for it then either the access key code is wrong or you have not entered it. Contact the supply if you have not got a key or the code doesn't work.
Dec 31, 2012 | Numark ttUSB Turntable
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
Nov 16, 2017 | Numark ttUSB Turntable
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
EZ audio converter hangs
not compatible with itunes 9 no solutiuon complain to numark turntables
Sep 16, 2009 | Numark PT01 Turntable
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Jul 25, 2009 | Numark PT01 Turntable
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
Won't Export to iTunes
it is not compatible with itunes 9 call numark and complain
May 29, 2009 | Numark PT01 Turntable
Jan 10, 2009 | Numark ttUSB Turntable
Unwanted recording overlays
Hey black fender start person, I'm genuinely sorry for sounding patronising and 'of the applemac-fool-mockery crew'. The needle-on-the-record is acting as a wall mic. I don't know about the ez software, but I'm guessing there are default settings in there somewhere, in tools/options or suchlike.
Have a look at the mic settings you might be able to apply some pleasing preset.
good luck :)
Jan 10, 2009 | Televison & Video
Numark ttUSB Turntable Logo
76 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
