Question about Numark ttUSB Turntable
Ez audio convertor stops recording after 1 min
Downloaded newest software version 10...stops recording after 1 min
  • Numark Master
  • 5,484 Answers
You are using a trial version. Unless you pay for the full version you only will get one minute. If you have paid for it then either the access key code is wrong or you have not entered it. Contact the supply if you have not got a key or the code doesn't work.
Posted on Jan 06, 2013
While recording from the turntable the recording stops automatically about a minute into it and says finished recording
It sounds like this is a software issue. Some makers have only a trial version of recording software. They only allow about 1 minute of recording time. In order to get the full version you have to pay a fee and they provide a registration code which gives you all features.
Mar 10, 2011 | ION Audio Vinyl Recording Turntable
KOn the ION EZ VHS 2 PC converter i get up to the part where i take the downloaded movie and try to burn it to a disk a message comes up and it says 'there is no media in the recording device. please...
What version of windows do you have?? Have you looked for updates? I have windows7 64 bit and downloaded the latest drivers. I'm finally able to capture movies however, I can't burn them to DVD I'm currently looking for software recommended on microsoft for doing this best of luck
Jan 24, 2011 | ION Audio VCR 2 PC USB VHS Video to...
1-I'm recorded my music 10-track on step 3 on EZ Vinyl Converter. 2-On step 5 export recording to iTunes take tolong to complete. 3-I'm access iTunes Music library. I see only 3 music track. 4-Can you...
The software is not 'seeing' the gap between the tracks, so it does not know the song has ended. Untick 'split recording into tracks' box, then sit with it as it records and click on new track every time a song ends. Tedious, but it works.
Nov 29, 2010 | ION Audio TTUSB10 Turntable
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
Do I need the latest EZ Ripper software download
always use the newest (highest) version number so in this case use the CD version of the software.
Jan 06, 2009 | ION Audio Vinyl Recording Turntable
VN240 PC software stops running as soon as you start it
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jul 07, 2008 | Olympus W-10 Digital Voice Recorder
DVD audio
You need to install a DVD decoder. Media player is horrible on it's own, but works great if you have other DVD decoding software. Try filehippo.com for the software.
Jun 27, 2008 | Acer Aspire 3610 Notebook
Numark ttUSB Turntable Logo
51 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
