Question about Optics
Seeing only black when looking through the lens
    Novelist:
    Champion:
  • 227 Answers
Can not help you set up correctly without make and model
Posted on Jan 09, 2013
I recently bought a Nikon FG, and when i look through the viewfinder all i see is black. I made sure the lens cap it's on, and its still black! I need to replace the batteries, but will that fix the...
Take the lens off the camera and look inside. you should see a mirror angled at 45 degrees. If you do not see the mirrir, it is probably stuck in the up position and repair is necessary
r
Apr 22, 2011 | Nikon FG 35mm SLR Camera
My kyocera camera sr3 lens the pictures are black the lens goes back & forth & when you look at pictures they are black it just happened because some pictures you can see i think theres a problem...
it is a problem with the exposure of the pitchers it could be the lens or shuter or the chip behind the lens its not letting any light in,, best to drop it off at a camera shot to see how much it is to fix it,, but you may find its cheeper to buy a new camera
Oct 31, 2009 | Kyocera Finecam S3R Digital Camera
CAn veiw old picture but the evf/lcd screen is black?
HI
got the same problem with my camera, was wondering if you found a solution..
if you did please e-mail me
dscullen@blueyonder.co.uk
Jun 19, 2009 | Fuji FinePix S5000 Digital Camera
Review windows is black, pictures are black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 12, 2009 | Cameras
I only see a circle when looking through the viewfinder instead of the rectangular area.
Sounds like the aperture / iris might be locked... presumeably its rectangular when lens is off camera (or trying another lens).
May 05, 2009 | Canon EOS-5D Digital Camera with 24-105mm...
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
Sony handycam "carl zeiss lens 40xoptical zoom
A common problem in the Sony camcorders is a stuck iris assy, the part of the lens assembly that regulates the light coming into the camera. It sounds like that is the problem with your camcorder. It can be verified by zooming your lens out and it and shining a light into the lens to see it you can actually see the CCD at the back of the lens. It helps if you know what you're looking for, but if all you see is black, then the iris is stuck closed and you will need a qualified tech to look at the unit. Please, if this information has answered your question, I would appreciate a good rating. Thanks!
Oct 23, 2008 | Video Cameras
Repair of digital camera
If you see all black in the viewfinder something bad has happened to the lens. It could be stuck, tilted, etc.
It will need to be taken apart and serviced by a trained technician.
Nov 14, 2007 | Nikon Coolpix 5700 Digital Camera
Black screen
It sounds like the shutter mechanism in your lens has stuck closed. This mechanism blocks out the light when you push the button to take a picture, allowing the image sensor to record what it saw just at that moment. If the shutter sticks closed then the image is always dark. You can see the shutter when it is closed from the outside, this is probably what you see when looking into your lens. Fixing this problem generally requires complete disassembly of the camera body and lens to reset the malfunctioning elements. Check with your manufacturer for recalls or technical bulletins, and see if they will fix it under your warranty. If this does not work out you can find good service providers online who can work on your camera. David Millier Advance Camera Repair
Feb 27, 2007 | Sanyo Xacti E6 Digital Camera
Can't see out of viewfinder
The mirror motor is probably the problem, you'll usually hear a whirring noise like a motor spinning. It's about a $125 repair, requiring the mirror box to be removed and the mirror driving motor replaced. Pentax originally put a plastic gear on the motor shaft - the replacements have a brass gear.
Nov 25, 2006 | Pentax ZX-30 QD 35mm SLR Camera
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
