Question about Blomberg WM67121 - 24" Front Load Washer - White
Change blomberg washer filter
How do remove the water filter It does not appear to rotate as one of the lugs is held in place by a socket that not allow the lug to rotate forcing the water filter to rotate with pliers might break the plastic
  • deepcove Dec 31, 2012
    This was NOT helpful. it just leads me to the manual which I have consulted and does not show how to remove the filter. and it was a come-on fro part sales. inane useless reply.
  • Blomberg Master
  • 17,129 Answers
Check this link for tips
Repair tips
Posted on Dec 31, 2012
How to reset Blomberg DWT23100W computer?
Remove lower dish basket and inspect where water drains looking for clogged inlet
Jun 02, 2014 | Dishwashers
Chevy camao
Not necessary to remove axles. Remove drum or rotor, hammer through the damaged stud, has room to fall out behind axle flange. Insert new stud through opening, A stud installer is preferred at this point, however, you can also use a couple of stacked washers and a lug nut. grease the washers, place them over the stud, grease the stud threads and then thread on the lug nut. With a socket wrench ,crank the stud down. The splines on the stud will bite in , keep turning until stud base meets axle flange. A new lug nut may be required , the one you use as an install tool may get damaged.
Jan 08, 2014 | 1998 Chevrolet Camaro
I need to change the oil and oil filter how mutch oil do i need and what grade for a citroen xsara 1587cc petrol
Oil filter replacement:
1. Removing:
"a" tabs
(1) Filter element protective cover
(2) Seal
(3) Filter element of the oil filter
(4) Plunger tube.
Untighten the filter element protection cover.
The filter element protection cover incorporates a 27 mm on flats Allen screw with 2 lugs at "a" which enable it to be held in a Facom S27 HLA socket.
Remove the cover (1).
2. Repair: When removing the filter element, the plunger tube ( 4) frees the oil return pipe, thus permitting the oil remaining in the filter element to return to the engine sump.
The filter element ( 3) and plunger tube (4) assembly should be replaced at every service.
Filter element protective cover : Tightening torque : 2,5 (0; -0,5) daNm. Proceed in the reverse order to removal.
Nov 10, 2011 | Cars & Trucks
2001 e39 windshield washer pump relay. Where is it located? I have a continuous 9 volt power to the pump with the ignition off and it appears to have burned out the pump. Need to check the relay, but...
Hi dtkorakbiak,
You will need to remove the passenger microfilter cover under the hood. First remove the filter cover. Then release the tabs holding the delivery tube to the filter housing. The housing lifts up and rotates out out to the side. Under the housing you will find a white plastic cover being held in place with 4 allen bolts. Using a 5mm allen remove the bolts. Once removed, under the cover you will see several control units and fuses and relays. Look for the BROWN relay. That relay is for your wiper/washer system. They do fail after a while. When reassembling the cover. make sure it is seated correctly, if not water can enter the electronics and create problems down the road.
Jun 20, 2011 | 2001 BMW 5 Series
I bought a blomberg DWT36240 back in Feb 27 2009. no problems till now. When I put the washer on it just hums with no water cycling through. It will run till i manually shut it down I have cleaned the...
I have the same model, they recalled the pump. Get ahold of where you bought it and see if you can get their repair companies contact info. Blomberg is next to impossible to contact in Canada, not sure about the US.
Nov 15, 2010 | Dishwashers
Need to change a front wheel bearing...is it hard to do myself?
moz-screenshot-2.png-Jack up the car
-remove the tire, 19mm socket
-remove the brake caliper, its either an 18mm or 15mm socket that will remove the bracket bolts.
-remove the rotor
-remove the axle nut, its either a 34 or 36 mm
-unplug ABS sensor connector if equipped
-remove the three bolts that hold the bearing/hub assembly to the knuckle, a 13mm socket will work
Remove the wheel bearing.
It is important to tighten the axle nut to the proper spec. Failure to do so will cause the new bearing to fail. you will need a 1/2" torque wrench for this.
To make removing and installing the axle nut easier place a punch in the fins of the rotor and rotate the rotor until the punch rests on the caliper (it doesn't hurt to put a couple lug nuts on to hold the caliper tight to the hub). This will hold the hub in place while you looses and tighten the axle nut.
Nov 09, 2010 | Chevrolet Tahoe Cars & Trucks
Top Loader LAT9406AAE s/n 23257742UQ Will not operate in any mode
if the washer will not fill I would change the water inlet valve. this could be the problem for all other issues. if the machine has no water in it, likely the timer will not advance to wash.
Oct 27, 2009 | Washing Machines
Can not remove lug nut caps 2003 x -type jaguar
I have an 04 xj8. the lug nuts are a good bad example of half baked engineering. the lug nuts are fabricated from ugly steel with an 11/16 hex end. to beautify this, Jaguar overlays the nut end with a stainless steel 3/4 inch cap, crimped to the nut. On top of this, the nut is to be torqued to 90+ ft-lb! The only way to remove the lug nut without damage is with a SIX POINT socket and a breaker bar or an impact wrench. Using a 12 point socket will deform the cap, causing the wrench to spin on the cap and or the cap to spin on the nut itself. If that has happened, it is possible to recover using a 15 oz or thereabouts ball peen hammer and a deep 3/4 inch impact socket (the black ones). Line up the socket to the cap, doing a best guess to where the flats are and give the socket a light blow. Keep trying that until the socket seems to stick on, then hit it harder. Eventually you will find the right point and the socket will go on and reform the cap. Then a breaker bar can remove the cap/nut. New assemblies can be had for about $6 from "partsbin" or "autohausaz".
Apr 11, 2009 | 2003 Jaguar X-Type
I changed the filter and got no ice.
Have you made sure that the rotator forks aren't jammed by an errant piece of ice. If the forks cant rotate you wont make ice no matter what. This is the #1 problem I have seen on ice maker repairs. Check it out , hope this helps.
Feb 10, 2009 | Refrigerators
Hotpoint aquarius wf325 filter problem, not accessable??
If you are certain that your washer has no filter at the front behind the lower removable panel, it is usually held on by 3 scews which you have to undo, or just held in place with plastic lugs, then you will have to remove the lower rear cover of washer. Locate large black hose at lower right of tub, remove clip and hose.
inside you will see the plastic filter,
Remove and clean filter, refit filter and plastic ball if it has one, refit hose and clip securely, and water test for leaks.
Be careful when you remove hose as there will be water run out.
Please make sure you have it unplugged before you do all this.
Plz rate my solution, and feel free to leave any comments.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Blomberg WM67121 - 24" Front Load Washer - White Logo
239 people viewed this question
Top Blomberg Washing Machines Experts
debbie
Level 1 Expert
ray gallant
paul
paul
Are you a Blomberg Washing Machine Expert? Answer questions, earn points and help others
