Question about Toys
No spring and catch any way to do this without a catch and spring
    Genius:
  • 1,669 Answers
Drill a small hole in the bottom piece (the part that is broken off and insert a paper clip or small piece of wire in the shape of a C to act as a catch to fit in either of the 2 holes.
Posted on Dec 31, 2012
How do i install a replacement spring in a tool catch
it isn't obvious from the pics but if I had to guess u need to get both the catch and the spring (if u lost it) b/c the reason the spring came out is that the catch is already broken.
Once u get it, it simply pops into place.
look at this page - may help
http://www.vacpartswarehouse.com/Dyson-Silver-Tool-Catch-DC25-DC33-DC35-DC44-DC56-p/dy-911523-03.htm
Sep 21, 2014 | Dyson DC35 Handheld Vacuum
Sears craftsman manuals?
You can't get sears manuals. If you remove the recoil assembly and turn it over you will be able to turn it. If the spring catches and starts to wind then you know your spring is good and you don't have to replace it. If it doesn't spring when wound replace spring. When ready turn till spring is fully wound ( can't wind anymore without force) then back it off until the rope holes line up. Install rope and handle and retract slowly. Pull handle a few times to make sure its not sticking and retracts properly. Reinstall on engine
Jul 27, 2014 | Garden
Brake band 3120xp
This job os not to be taked on lightly, remove the hand guard by taking away the securing screw and pivots, be aware if you remove the roll pin without locking the spring and catch the locking lever can fly out under spring tention, i lock the top of the spring and catch, and the lower end of the spring in a vice ( this means the vice jaw is where the sprocket would sit, so be carful not to damage the cover ) then take the roll pin out, the top catch screws onto a thread on the band, be sure to count how many turns the catch is on the thread and re fit the same on the new band, it does not just bottom out
Feb 04, 2013 | Husqvarna 3120 XP Saw
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
My samsung ml-1630w printers paper tray seems to pop open
you may want to check on the try. the try have 2 nod that is holding the spring from releasing. the nod can be located at the try.
2nd you may want to check on the try button, is the spring giving way.
to check on the sping remove the try & toner. but the printer upside down. press on the try button you should be able to see that there is 2 white catch that is holding the try. if the catch has give way. you got to dismantle the printer to adjust it.
Jan 01, 2010 | Samsung ML-1630W Monochrome Laser , up to...
Husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Mar 23, 2009 | Husqvarna Garden
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Door catch
require diagram of parts for zannusi and their description
Aug 11, 2008 | Zanussi TD4112W Electric Dryer
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
