Question about Cell Phones
Can not add network - Cell Phones
    Master:
  • Cell Phones Master
  • 520 Answers
Hello::
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Dec 31, 2012
How do I add a printer to the network?
How to create an IP address into your Printer
1, Connect to LAN network
2, Power ON the Printer.
3, Select MENU Button
4, Go to System Settings, then select Network Settings.
5, You can see TCP/IP , View IP ,etc.....
6, Type Your Printer IP address, Subnet Mask, GateWay, etc...
7, That's All......
In different Printer settings will be different.
Now You can add printer into your computer
Go to Control Panel--> Hardware and Sound -->Device and printers -->Add Printer-->Add network Printer-->"If no printer were found" Select "The printer that i want isn't listed" --> Add printer using TCP/IP--> Type your Printer IP address--> Now you can install printer software...
Thanks
Oct 10, 2012 | Canon imageCLASS MF4370dn...
Tip
Add network support to windows 7
By default, <b>Windows Live Movie Maker</b> will not let you upload files on a network, but a quick registry tweak will change this. <b>Run regedit</b>, go to HKEY_CURRENT_USER \ <b>Software </b>\<b> Microsoft</b> \ <b>Windows Live</b> \ <b>Movie Maker</b>, you must add a DWORD value named AllowNetworkFiles and set it to 1 to add support network.
on Feb 25, 2011 | Computers & Internet
Hi Team, My phone does not automatically connect to my home wifi. How do I get it to do that? Thanks B.
By default, Android will remember. If due to whatever reason it 'forgot' then you may add it manually.
1. Go to Wireless & networks menu
2. Select Wi-Fi settings
3. Choose a listed network, or add a hidden network by selecting add Wi-Fi network
4. If the network is encrypted then enter the password.
5. If your home network is not broadcasting (hidden network), then select Add Wi-Fi network and enter the SSID name
6. Provide the WEP/WPA key.
Hope this helps
Mar 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
How to get phone on home internet
1. Click Set Up Wi-Fi.
2. Click Next.
3. Click Manually Add Network.
4. Type the network name or service set identifier (SSID).
5. Click Add.
6. From the Security Type menu, select the security type for
the Wi-Fi network.
7. Specify the required security credentials.
8. Click Connect to manually add and connect to a Wi-Fi
network.
Jan 05, 2011 | AT&T Blackberry Curve 8300 Smartphone
How do you add this printer to the network?
for networking take the configuration page & note down the default ip add then open the internet explorer & note down the default ip & enter you will conect the printer directly then change the ip add as per ur requirement & uncheck the dhcp .
hope ur problem will be resolve...
Jul 01, 2010 | HP LaserJet 1320 Printer
How do I set it up for wireless
Install a printer on a home network The most common way to install a printer on a home network is to install it as a stand-alone device on the network, and then add a connection to the printer on each computer that is on the network.
If you're not sure what type of network printer to install, decide if you want to:
  • Use a wireless printer. These printers use a built-in wireless card and plug into a power source, not your network or computer. After you turn on the printer, you need to refer to the information that came with the printer to set up a wireless connection to each computer on a home network. Security options for wireless printing are determined by each printer manufacturer.
  • Connect a printer directly to the network. To do this, you need to plug in the printer to your network hub or router. How to install these printers depends on whether the printer and your network device use an Ethernet, universal serial bus (USB), or another type of connection. You also need to refer to any installation information or tools provided by the printer manufacturer.
  • Connect more than one printer directly to the network. To do this, your hub or router must be able to support more than one printer connection.
Hide all expcol_imgs.png To install a network printer
  • To find out how to install a network printer, check the information that came with the printer.
expcol_imgs.png To connect to a network printer After you have installed a network printer, you need to add a connection to the printer for each computer on the network.
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. On the toolbar, click Add a printer.
  3. In the Add Printer Wizard, select Add a network, wireless or Bluetooth printer, and then follow the steps in the wizard.
Feb 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
How do I network brother mfc-440cn printer - what
  1. Plug the printer into a computer on your network.
  2. This computer must be on and remain on for the printer to work.
  3. Add this local printer to this computer in "Control Panel" - "Printers".
  4. Now share the printer.
  5. Go to another computer on your network.
  6. Add this printer (as a network printer) to this computer in "Control Panel" - "Printers".
  7. The system should find the printer and add it...
Nov 15, 2009 | Brother MFC 420CN All-In-One InkJet...
I need to add a password to my wireless network
Do you want to secure the wireless network ?
For that you will need to access the router set up.
You said that you want to add a password. I don't understand that. Is your wireless network already secured ? Or you want to make it secured ?
If it is already secured then it must have the password to connect to the wireless network. You can use only 1 password for the network. You can not use 2 password for the wireless network.
If your network is not secured yet then you will need to make it secured and enable password protection on it.
Click Here to know more about how to make it secured
Nov 12, 2009 | Computers & Internet
Have forgotten NetKey password to add laptop to wireless network
Just reset the router and you can configure it again like before.
Jul 01, 2009 | Linksys Wireless-G WRT54G Router
Howto add a network printer on Wyse winterm S30 terminal?
The S30 terminal has the CE 5.0 operating system loaded as default. So you are limited by the operating system and not the hardware when it comes to network printing.
Here is a extract of the release notes for Windows CE 5.0:
"In Windows CE, TCP/IP supports network printing through the Server Message Block (SMB) protocol. It does not provide the Windows Line Printer Remote (LPR) Spooler. However, independent software vendors (ISVs) and original equipment manufacturers (OEMs) can add this support."
In short, you need a 3rd party software program or a (SMB) printer server setup to setup network printing on the S30 terminal..
Wyse also have add-on software to help, if you have CE 5.0 loaded then try the "Thinprint" add-on supplied as a free download by them.
Download Link:
http://www.wyse.com/supportdownload/3series/Addon_ThinPrint_B0010.exe
I haven't tried this, so let me know if it works.
May 02, 2008 | WYSE Winterm S30 Network Terminal
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
