Question about Uniflame 200209 Open Flame Patio Heater
Sunjoy L-PH018PSS patio heater owners manual
Is there a battery in this patio heater to help with automatic lighting and if so, where is it located?
5 Suggested Answers
  • 9 Answers
SOURCE: Patio propane heater shuts off after 15 minutes
Before you go changing parts, clean up the pilot assembly. When you heat metal and let it cool and heat it again it causes it to corrode. Also for some reason these areas seem to attract little spiders who make their homes here. This causes gas flow problems which in turn could affect the size and direction the pilot flame. For if it does not touch the thermocouple, thermopile or whatever that little thingy is called that tells the gas valve to allow the gas to flow...it will not tell the gas valvle to let it flow. Remove the corrosion, spiders, spider webs and any other insects then sand the thermocouple, thermopile or whatever that little thingy is with a rough sandpaper to remove corrosion. It will likely work after that.
I am very familiar with this heater, unfortunately. I posted the instructions on another problem with this same type heater to take it apart, clean and service it. That should be helpful.
Posted on Mar 24, 2010
SOURCE: On my Sunjoy G-PH018PSS patio heater, the starter
The flames on my Sunjoy G-PH018PSS burn yellow instead of blue. What is causing this problem?
Posted on Dec 20, 2009
  • 9 Answers
SOURCE: Sunjoy L-PH018PSS Patio Heater Replacement Parts
What is likely happening is that the pilot flame cannot reach the thermocoupler. This is usually caused by corrosion or other blockage of the gas to the area where the pilot lights. Thus resulting in a small flame or no flame on the side the thermocoupler is located. Fix this by cleaning out the corrosion or other blockage in the pilot assembly. I have found that small spiders like to make their homes here which causes the blockage of the gas for the pilot. The pilot assembly has three parts to it. The ignitor electrode, the pilot light tower, and the thermocoupler. The ignitor electrode has a wire that goes from it to the push button ignitor. The pilot tower is located in the middle and has a gas line going to it from the gas valve (control knob). The thermocoupler stands next to and on the opposite side of the ignitor electrode. It also has a copper line from it to the gas valve.
Unfortunately, the Sunjoy you have, which is the same model of two I have to keep running, is difficult to service. Parts are not readily available either so be careful when you take it apart. They do not sell the individual smaller parts in this model and therefore make you buy complete assemblies.
To clean and service the pilot assembly, remove the screws holding the front plate on where your control knob is. Once that is removed you can see the back of the ignitor, it is black and has one wire coming from it leading up to the ignitor electrode. You will also be able to see the small gas line from the gas valve going up to the pilot tower and the small copper line from the gas valve to the thermocoupler. That assembly is what you need to get to, to clean.
You do that by removing the top canopy by removing the three screws holding it down. Once that is removed, remove the center nut on the heat exchanger (the part that heats up with all of the little holes). It is located on the top and in the center of the heat exhanger. Then remove the three screws that are located around the bottom of the heat exchanger that connects the collar to it. You should be able to remove the heat exchanger now. Tilt the whole heater down and prop the neck on something so you can work on it.
If you look in the top you will be able to see small metal box covering the pilot assembly. This is held onto the pilot assembly with two screws. Remove those screws and carefully remove the box. Now remove the two screws that holds the pilot assembly to the collar (located on the outside of the collar). The gas and copper lines will hold it up. If you look at the pilot assembly from the top you will see one screw holding the ignitor electrode to the pilot assembly bracket. Remove that screw, unplug the wire from the ignitor and remove the ignitor electrode from the assembly. Be careful not to break this and I am having you remove it so that you do not break it.
Now remove the nut that holds the thermocoupler onto the pilot assembly bracket and pull it out of the bracket. The copper line will hold it up and be careful not to kink the copper line. Take a piece of sandpaper and clean the outside surface of the thermocoupler. Corrosion on the thermocoupler could cause it to fail which will cause the pilot not to stay lit. I have not had one do that yet but it could happen.
Now, remove the gas line from the bottom of the pilot tower so that the tower and bracket are in your hands. Put it down and put the heater back up straight. Hook up your gas and turn the gas on. Now, press the control knob on the pilot setting to make sure you have gas coming out of the gas line that feeds the pilot. You should be able to hear, feel and smell it. If not you have a regulator problem or an empty tank. Turn off your gas, remove it from the heater and tilt the heater back down.
Take your pilot assembly, you will see a circular top to the pilot tower that is held down with really small metal ears. Carefully bend the ears back so that you can bend the top of the tower back. Only bend it back far enough to clean the inside of it with a bent wire and compressed air or something. If you look on the lower side of the bracket, above where the gas line is threaded on you will see a hole that goes all the way through the assembly. This hole regulates the pilot gas pressure and allows the gas to mix with the air before it burns. Make sure that hole is clear of debris and take wire or something and thread it through the hole up through the top side of the tower.
When you have it clean, reconnect the gas line, thermocoupler and ignitor electrode. Once reconnected and before screwing the assembly back to the collar, I set the heater back up right and reconnect the gas. I then light the pilot to make certain you have a good strong pilot light generously touching the thermocoupler. The pilot should stay lit haver holding the button in for a few seconds. Do not turn the heater on past the pilot area without the heat exchanger on or you might singe your hair. If the pilot works the way it is supposed to, turn it off, disconnect your gas, tilt the heater back down and reassemble it following the intructions in the opposite manner.
The ignitor problem:
It is probably corroded in the cap (which is also the switch) or inside the ignitor where the battery goes at the spring. Spray these areas out with WD40 which will clean the corrosion out and try it again with a new battery. If it does not go click click click when you press the button you may have to take the ignitor out. Unscrew the cap and then the little black plastic collar which secures the ignitor to the collar. This should allow you to remove the ignitor by turning and maneuvering it out of the collar past the gas valve. Put the battery back in and replace the cap. Press the button to see if it works. Be careful it may shock you causing you to squeal, cuss and likely drop the ignitor.
I just had one do this to me. For some reason the little black collar that secures the ignitor to the heater collar would not screw all the way in. This would not allow cap to fully screw on and therefore would not allow contact with the battery to the contact inside the ignitor near the spring. Tighten it up as best you can so that contact can be made when you press the button. I believe this is one part you can order from Sunjoy separately if you cannot get yours to work....Good Luck
  • 4736 Answers
SOURCE: WHERE CAN I GET A
Bruce, Blue Rhino is the manufacturer of your Uniflame Patio heater. You can get replacements parts from them, by contacting their Customer Service Dept 1.800.762.1142
Hope this helps and thanks for choosing FixYa.
Posted on Jul 31, 2011
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light will light and stay lit, but will go out when you turn on the burner.
The most likley cause for patio heaters that light but go out when turned up is a worn thermocouple. These are consumable items that need changing when the patio heaters fails to light. Found this site very useful:
patio heater problem solving
Dec 31, 2012 | Stainless Garden Sun Steel Propane Patio...
Broken patio heater
Hi, Depends on what is broken. If it will not light the first thing to go on a patio heater is a thermcouple, but it could also be a tilt switch. Found this very useful patio heater guide to problem solving.
Apr 22, 2012 | Stainless Garden Sun Steel Propane Patio...
I have a Kirkland patio heater model # PTH-106SS-3G the pilot will not stay lit. Do I need to replace the whole pilot assembly
Hi, If the pilot light goes out when you turn the gas knob to full power on lighting them the most likely cause will be a worn thermocouple, these usually last between 2 years up to 6 years. Found this site very helpful, patio heater problem solving. They have a few solutions to checking patio heaters.
Oct 12, 2011 | Williams 2509612 Ceramic Mid-Size Heater
I hooked up my patio heater...but cannot get it to light...not hearing any gas sound...nothing seems to get it to go...any suggestions?
Some of the newer heaters have a pulse pilot, this is a very small flame that pulses away and can be hard to light first time. If it's new make sure to vent and clear all the air out. If an old heater take a look at this patio heater help pages, they have some help pages which I found very useful.
Sep 01, 2011 | Stainless Garden Sun Steel Propane Patio...
Replacement regulator required for Endless Summer patio heater
These regulators can usually be purchased from Canadian Tire or Home Depot. If you are unable to locate the exact replacement, email the model number located on the regulator and I will locate one for you. I am in the GTA and can be contacted via company website. www.emshvac.com
But one question, why do you think the regulator is defective? These rarely fail.
Nov 03, 2009 | Endless Summer ES92000 Patio Heater
Main Heater will not light off
turn the gas on real slow. The air in the line is blowing out the pilot
Aug 26, 2009 | Stainless Patio Heaters - Steel Deluxe...
Patio comfort heater won't light
Sometimes you have to completely disassemble the pilot assembly to clear the blockage, the orifice for the pilot jet is very small and you can not get directly to it unless you take it apart. If this does not help, you may need a new valve.
Jul 12, 2009 | Stainless Patio Comfort Natural Gas Steel...
Uniflame 200209 Open Flame Patio Heater Logo
372 people viewed this question
Top Uniflame Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mike
Are you an Uniflame Heating and Cooling Expert? Answer questions, earn points and help others
