Can you get me a diagram and schematic of the Hot Point Ultima Extra WDM73 1200 Spinn washer dryer?
I need the prints to help my daughter who is in Scotland, she can do it with my help but I need to see what i'm working on so I can realy it to her on skype. The problem is E15 on the readout which is probably the filter clogged, but I need to walk her though the steps of removing the panels and cleaning the filter.
SOURCE: Hotpoint ultima extra washer dryer WDM73
i found this manual,if you know what your problem is this might show how to change the faulty bit. I dont know what machine this is but they all seem pretty simular, i used this to change my door lock.
Posted on Jun 16, 2008
barkencoa
  • 3463 Answers
SOURCE: i have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Posted on Dec 09, 2008
  • 1417 Answers
SOURCE: my hotpoint ultima extra washing
hello,
what e15 indicate means an error code that there have been an over flow of water from the drum over to the panel or the wire that suppl power to the screen .
what you will have to do to fix up this problem from the screen is to unscrew the screws with screw driver care then trace the wire ,that is the power supply down to the panel and also to the screen clean up all forms of liquid around the wires and also the panel carefully . then couple it back with care to is position with this the problem is solve.
thank you.
Posted on Aug 07, 2010
SOURCE: E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Posted on Oct 17, 2010
grandadfixer
  • 99 Answers
SOURCE: hot point ultima 1600 dose my hot point ultima
yes because it wont rinse
Posted on Sep 18, 2011
Is there a schematic diagram for heatseal ultima 65 I need one.
not that I am aware of, the maint manual has a theory of operation block diagram, but no schematics.
Jan 28, 2015 | Gbc HeatSeal Ultima 65 Laminating System
E30 error message received for my WD72P HOT POINT ULTIMA EXTRA WASHER/DRYER
E30 means the motor isn't working on this machine. There used to be a 7.5 amp fuse on the power modules on these micro processor controlled washing machines which used to blow if the motor went faulty.
It could be that the brushes have worn out and the motor has blown the fuse. This can happen if they spark excessively but it can also happen if the armature goes down to earth, or the armature is faulty. You really need to test the insulation of the motor though with a specialist meter (megger)
Nov 22, 2012 | Washing Machines
My hot point will not fill with water the supply is ok
The screens where the hoses connect to the washer are clogged with mineral deposits, which is not allowing the water to flow into the washer. I've had the same problem.
Sep 03, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
How do i replace the belt on my hot point model DLB2654TA electric dryer can not find a drawing of the schematic for it anywhere
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. Look for the "Dryer Belt Diagrams" under the Special Features section. Depending on the age of your appliance, you will need to refer to either diagram M, D, or L. If you need further assistance, please let me know. I hope this helps you.
Jul 08, 2009 | Dryers
Need wiring diagram to conect pcb to a hotpoint ultima extra wma66
www.selfix-uk.co.uk for manuals on WM & WMA machines including wiring connection charts
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
