Question about Elna 1010
Elna 1010 won't sew. It isn't picking up the bobbin thread
4 Suggested Answers
Tally Girl
  • 1129 Answers
SOURCE: I was sewing a straight seam and all of a sudden
If you can hear a click then I'd say the needle is touching some part of the hook mechanics which could mean timing is out. However, it is possible that the bobbin case has just moved a little so as first trouble shooting steps, I'd suggest the following:
clean out the bobbin holder area as per manual (ie. remove the needle plate, bobbin, sewing foot and needle, take out the bobbin holder, clean the race area out, then put bobbin holder back in as per your manual, there is usually a stopper and knob or two red marks to line up. This is held by a magnet so it is possible to knock it out of place during a jam up.
Replace needle plate, bobbin, sewing foot and put in a new sharp needle, flat shank to the back and make sure it is fully up into the holder, thread up and very slowly using the needle up and down button, test sew a couple of stitches again.
If no stitch formation or you can definitely hear/see something touching then I'd say timing is out and no, its not something fixed yourself; best left to a trained technician.
Posted on Apr 12, 2011
Testimonial: "Thank you! I took it all out and found that the needle is indeed hitting where it shouldn't and had to take it in and need to borrow a machine...."
Tally Girl
  • 1129 Answers
SOURCE: My elna sewing machine bobbin
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Posted on Aug 02, 2011
  • 16 Answers
SOURCE: I have an Elna Lotus sewing machine. The needle
Most frequently the needle is just in backwards or threaded from wrong side, or using the wrong needle- check it over.... The presser foot must be released to press on fabric else the tension adjuster will be set to zero tension and could cause issue. Expect simple stuff else timing was knocked out of adjustment (from striking something, etc)
Take two adjustments and call me in the morning... for real, get back to me if it isnt anything basic I will try to describe timing procedure
Posted on Oct 21, 2011
Having trouble with the bobbin on an elna 1010, the thread bunches up
OIl on the bobbin will cause you problems as it affects the thread feed. Clean the area and check the bobbin thread rension.
Mar 11, 2013 | Elna 2007 Mechanical Sewing Machine
Not picking up bobbin thread
try rethreading the machine top & bobbin
put in a new needle
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin case is inserted correctly in to the machine
if the machine still doesn't pick up the bobbin thread it's possible that
the machine is out of time
Aug 28, 2012 | Elna 2005 Mechanical Sewing Machine
The thread on the needle of my Elna sewing machine wont pick up the thread on the bobbin and bring it up?
try changing the needle
if changing the needle doesn't help then it's possible that the machine
is out of time & needs to be checked at a repair shop
Aug 22, 2012 | Elna Sewing Machines
OK I CAN'T GET THE NEEDLE ON MY ELNA 1010 TOPICK UP THE BOBBIN THREAD WHY
sewing machine shop technican's have special tools to adjust the
timing on sewing machines.
if you do take the machine to be timed, when you get the machine
home,, sew on the machine right then to make sure that it sews
the way it's suppose to,
Jul 31, 2012 | Elna 1010
Elna lotus
try cleaning under the needle plate & in bobbin area for loose threads or lint
try using a new needle--make sure the needle is inserted correctly in the needle holder
if you try all these suggestions & the machine still won't pick up the bobbin thread then it's possible that the machine is out of time & would have to be retimed at a sewing machine shop
Mar 02, 2012 | Elna Sewing Machines
The flywheel on my elna special sewing machine won't tighten after winding on thread to the bobbin.
it's very possible that a part could be worn or jamed or even broken
only a sewing machine repair shop can tell what wrong
Feb 02, 2012 | Elna Sewing Machines
I have no manual for my Elna 1010 sewing machine. My question is how do I thread it and is there a blanket stitch on this machine. Thank you. Joan
There are several websites where manuals can be found:
http://www.tias.com/stores/relics/ has authorised reproductions of many Elna manuals for sale but not yours.
www.diplodocs.com is a free souce but no 1010 there.
www.sewingpartsonline.com is a great site too, and they have yours for sale $US15
link is
http://www.sewingpartsonline.com/instruction-manual-elna-1010.aspx
I don't know this model real well, but I'm guessing it is a front loading bobbin and bobbin case design maybe?? If so, you may well find that just looking at the instructions for any front loading bobbin machine will get you started,
try this link
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_225_threading_diagram.htm
These Elnitas 225, 244, 245 were front loading bobbin style but "made under licence" and sold by Elna. I think the 1010 may well be a similar design so see if these diagrams help get you under way.
Its always helpful to source the genuine manual if possible though so worth spending the money; manuals contain maintenance info as well as threading up, and different techniques and accessories usually.
Lastly, Blanket stitch. I presume you mean the big chunky stitch where you turn an edge over and it looks like a straight line with a diagonal stitch going to the folded edge at regular intervals like this.
tally_girl_77.jpg Some sewing machines do a similar "overcasting" stitch but it won't be big like you might want on polar fleece or a blanket edge. The commercial blanket stitch you see on blankets will be done by a special purpose industrial machine and it applies a single thread just as you would when doing a blanket stitch by hand. So look at the stitch selection dial on your machine and see if there is something resembling a blanket stitch but it usually would only be 4mm wide, the maximum your machine probably can stitch.
So if you want a genuine blanket stitch, its a needle and heavy thread hand job, there are instructions on how to do at www.sewing.about.com, link is http://sewing.about.com/od/beginner1/ss/blanketstitch.htm
Sep 22, 2011 | Elna 1010
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Why won't top thread pick up bottom bobbin thread
Simple things to check are:
Needle in backwards?
Winding the flywheel the right direction?
Is machine and bobbin threaded up correctly?
More serious reason would be timing is out; this happens if you've struck a pin, sewing foot or zipper hard and is something for the machine technician. But try the simple stuff first.
Feb 05, 2011 | Elna 1010
Thread breaks on the bottom when sewing
check the needle to see if it's damaged
lower thread tension may be to tight
check to bobbin & bobbin case for burrs
check for loose threads in bobbin area
Sep 23, 2010 | Elna 1010
Sewing Machines Logo
46 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
