Question about Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop
Inspiron 531 / vista restore
The hard drive is completely wiped, partitions deleted and re set and formatted to NTFS. I'm trying to install vista home basic from disk, I try to install drivers for the hdd and it fails halfway through, Bios does not let me choose kind of hdd it's all pre-determined. Install just loops me through the same failed process.
  • Dell Master
  • 27,725 Answers
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios. Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system. Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd\dvd. Hope this helps.
Posted on Dec 31, 2012
  • Hen Brac Jan 03, 2013
    the computer installs the driver to X: drive which is a virutal drive. The moment a restart is required everything in a virtuial drive gets wiped and you simply go in a circle. I can get to a dos prompt and control the drive, format etc manually but windows vista says it can't detect the working drive, the bios does not allow for any changes in the drive either.
  • Brian Sullivan
    Brian Sullivan Jan 03, 2013
    did you sign as as the computer administrator click start control panel administative tools computer management disk management you should see all of your drives right click assign a drive letter there
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: I have a dell inspiron 531 that had the hard drive formatted by a virus and my disks will not restore vista home
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download
Download and install at least one of these all free depending on your operating system http://download.cnet.com/avg-antivirus-free-2013/3000-2239_4-10320142.html
avg free 2013 http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials Hope this helps.
Posted on Dec 29, 2012
How to restore factry default settings
Hetman NTFS Recovery recovers files and folders from all types of hard drives formatted with NTFS, including SSD drives and external storage. The NTFS file recovery tool can perform a simple undelete operation to recover deleted files or perform a comprehensive data recovery procedure, extracting all files and folders from the damaged NTFS volume complete with the original folder structure.
Hetman NTFS Recovery recognizes and recovers NTFS alternate data streams, and supports the recovery of compressed and encrypted files. The NTFS recovery tool works in all 32-bit and 64-bit versions of Windows including those that do not natively support the NTFS file system.
Key features
• Offers the best value to users of modern versions of Windows (Windows XP and up) thanks to exclusive support for the FAT file system;
• Unformat formatted partitions and restore original volumes from repartitioned hard drives;
• Undeletes all types of files including pictures, music, videos, documents etc.;
• Recovers data from formatted, corrupted and inaccessible NTFS disks and SSD drives;
• Restores files from formatted NTFS volumes and repartitioned disks;
• Extracts information from volumes with broken file systems, damaged partition tables and master boot records (MBR).
I also attached a link to the video instructions and a link to the site
Apr 18, 2013 | Office Equipment & Supplies
Computer doesn't recognize internal drive installing vista
Drive 0 means that it is the first (or only) drive plugged in. You should use a partition manager to format the hard drive to give it a partition. After you have a partition made (NTFS format) it should show up!
Nov 04, 2012 | Computers & Internet
Fix BIOS on Dell Inspiron 531 Vista Home Basic 32-bit
The BIOS may require flashing when an update is available or when replacing the system board.
  1. Turn on the computer.
  2. Locate the BIOS update file for your computer at the Dell Support website at support.dell.com.
  3. Click Download Now to download the file.
  4. If the Export Compliance Disclaimer window appears, click Yes, I Accept this Agreement.
The File Download window appears.
  1. Click Save this program to disk, and then click OK.
The Save In window appears.
  1. Click the down arrow to view the Save In menu, select Desktop, and then click Save.
The file downloads to your desktop.
  1. Click Close when the Download Complete window appears.
The file icon appears on your desktop and is titled the same as the downloaded BIOS update file.
  1. Double-click the file icon on the desktop and follow the on-screen instructions.
Aug 14, 2012 | Dell Inspiron 531s Desktop Computer
Erase hard drive before returning computer?
If you mean wiping out all the data and operating system then -
This is generally howyour format the hard disk and install Windows.
First you need a Windows XP or Windows Vista installation CD and the productinstallation code, which is printed on the Windows label on the bottom of yourlaptop.
Boot up with the Windows installation CD start and follow the instructions toinstall Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quickformat. This will prepare the Windows for a clean install.
If you do not wish to continue installing Windows then Exit and shut down the computer.
Mar 15, 2012 | HP Computers & Internet
I am returning a computer I've used for aboput a month. How do I erase the hard drive first?
Can you please give me step by step insturctions on how to totally wipe my hardrive on my dell latitude 600? Then I will refoat it back to its orignal settings. thank You
Unless you're donating the drive, there's no need to do anything before re-installing the OS. When Windows asks where you want to install the OS to, you'll see an option for formatting the drive first.
If you are donating it and are worried about someone recovering the data (after formatting and re-installing, it's not something the average tech can do) I'd recommend booting the laptop off CD/USB drive with this image (http://www.ultimatebootcd.com/) and running one of the Hard Disk Wiping utilities. Mind you, some of the very thorough ones (military-grade) can take DAYS.
Jun 29, 2011 | Computers & Internet
Administrator password Dell Inspiron 1720
If the system is asking for an administrator password in Windows and you are wanting to format and reinstall the system, then the password shouldn't be an issue. Most inspiron systems are equipped with a PC Restore partition CTRL+F11 just after the Dell Splash Screen should enable the restore process. If PC Restore doesn't work, then boot to the XP CD and format the NTFS partition and install Windows XP clean. If you have Windows Vista, the PC Restore is run from the F8 Boot menu. If no restore partition is accessible in Vista, then again Boot to the Vista DVD and format the NTFS partition and install VIsta.
Sep 30, 2009 | Computers & Internet
I need to completely format my pc but can't remeber how. System restore not available this time.
If you want to completely erase all data on your hard drive, and start with a fresh installation of Windows, the process is pretty simple. Boot to you Windows Media Disc, delete the existing Windows Partition (Normally the 1st NTFS partition) then create a new NTFS partition, format it, then install WIndows to that partition. After the Windows installation completes, then install the drivers (Normally in this order:)
Desktop system Software (Dell Specific)
Chipset
Video
Audio
Modem
Network
Wireless (If Equipped)
Touchpad (If Equipped)
Card reader (If Equipped)
Sep 28, 2008 | Computers & Internet
Reformat
Insert the winxp disk and boot from that, when prompted hit any key to boot from cd.
Win xp will start to install choose to delete the partition, confirm delete.
then press enter to install to that unallocated partition, choose format to NTFS.
Follow the prompts and it has formated the hard drive and will install XP.
Apr 30, 2008 | Dell Inspiron 8500 Notebook
Open Questions:
Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
