Question about Ford Vehicle Parts & Accessories
Ford automatic transmission oil leak at wiring socket
AU falcon auto transmission has an oil leak at the wiring socket - want to know how to remove the socket and stop the leak without damaging it, and without removing the transmission from the vehicle
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 207 Answers
Sounds like a worn gasket.
Posted on Oct 21, 2013
How do i bypass the smartsheild on a 2001 au ford falcon ute.i cant start because the smartsheild comes on an jams the motor?
the problem was raised in the australian AU ford forum not so long ago
you cant bypass it
ripping out wires without knowing ... just causes more grief
have to use a scanner to re set system
or find which module of the smart shield has failed
AuII Smartsheild question
fordforums com au
i have the downloadable repair manual for that AU
one download only.. not for resale etc etc
Ford Falcon AU 1998 2002 Workshop Manuals Factory Service Manuals
Oct 17, 2016 | Ford Cars & Trucks
Where do you add automatic transmission fluid in 2000 ford futura au
in a plug on the side of the gearbox under the car (16mm),running in "D" with the engine running at 1000 rpm with the box warm but not hot,pump it in until it runs out of the plug, a pit,hoist or solid ramps will be needed for this as well as 2 people
Oct 16, 2014 | 1999 Ford Falcon
Au falcon auto transmission slips in reverse
Trans mission needs to be overhauled or replaced. Good Luck
Dec 18, 2012 | 1999 Ford Falcon
Leaking transmission oil from the back of the gearbox and front axel on ford falcon 1991 eb wagon,post diagram of auto transmission box
YOU carnt have a transmission oil leak from the front axle on a Falcon as they are Rear wheel drive but could be the hose going to the radiator over the front end leaking But the rear end of G/Box should be only the OIL SEAL.
Sep 19, 2009 | Ford F Cars & Trucks
Where do you top up the auto transmition fluid on the au falcon
This is a sealed unit and cannot be topped up exept from the inspection plug at the base of the unit..
Sep 17, 2009 | Ford Fairmont Cars & Trucks
Auto trans fluid top up on AU falcon
get new plug 1st then use plenty CRC ,hammer and blunt chiesel or blunt centre punch to crack plug(turn around or undo)
Aug 02, 2009 | 2005 Ford Futura
Leaking rear seal on a ED falcon auto transmission
They sell seal pullers for the engine, it may work for the tranny. Check around to make sure the seal comes out the back, and not forward thru the housing with the tailpiece off. I would have the back of the car way up so oil doesn't come out, maybe drain the oil first. If the seal is worn out, you know the rear sleeve bearing in the tranny might be worn out too. It will just leak again.
Apr 28, 2009 | Ford Fairmont Cars & Trucks
1998 au falcon automatic transmission, car wont start in park
check the neutral safety switch, sounds like it needs to be replaced. countrcurt0
Aug 15, 2008 | 2005 Ford Futura
Vehicle Parts & Accessories Logo
98 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
