Question about NetGear WGR614 Router
Emails problems will not send out
I purchase a Netgear WGR614 and secured the router, know I can't send out e-mails.I log on to a surrounding unsecure network and mail goes out. I can recieved mail all day. Can someone help? I 've call Netgear Support several times not help!
  • Anonymous Mar 30, 2014
    I've just upgraded my router
Well first off, let's see if you can even connect with the outgoing email server. Here are some steps. 1. Connect with your wireless connection. 2. Goto Start, Run and type in cmd. 3. A DOS window will open 4. Type ping "your emails outgoing server" i.e. mine would be smtp.cox.net, this can be found in our outlook account settings. 5. If you get 4 replys then we know it's not your router and most likely some software on your computer not letting your email through. 6. Connect with the unsecured network. 7. Repeat steps 2-4 8. If you get 4 replys on the unsecured network and none on your network then we know it's something in your network. If it's the ladder then I will need your router's version number since there are 7 versions of your type of router (version number found on bottom of router), and we can go from there.
Posted on Jun 24, 2007
    President:
  • 2,961 Answers
It shouldn't have anything to do with the router, the ports for emails are automatically opened and allowed by windows, assuming you are using outlook or similair you should not have been able to send emails using another connection as you would have to change the smtp settings to send mail through the connection server, in this case if you have a internet security programme you may find it is checking outgoing mail for viruses and sometimes they get put in your outbox and never sent, if this is the cas dissable scan outgoing email in your security software. If you are sending mail through your online mailing web page eg. hotmail then there is a problem with the e mail you are sending perhaps too large a file or a file that requires you to zip it for security reasons.
SOURCE:
I had to reset my netgear router.It now shows that it is unsecured.How do access the router and secure it again?
Here is a setup page for the NetGear WGR614
http://www.columbia.edu/acis/networks/aptnet/netgear/index.html
Aug 04, 2011 | NetGear WGR614 Router
I have used the netgear wgr614 wireless router in unsecured mode to run two laptops for a couple of years now.... yes, I know that is stupid....now! So after a security breach, I realize I need to secure...
  1. Install the router. To install a Netgear wireless router, use an Ethernet cable to connect the router to the cable/DSL modem and use another Ethernet cable to connect the router to your computer. Make sure all of these devices are powered off as you connect them. Once connected, turn on the cable/DSL modem, the router, then the computer, in that order. Allow at least two minutes to pass after turning on each device to give the devices time to recognize one another.
  2. Log in to the router. Open a web browser and type in the router's address to load the router's settings page. The router's address can be found in the user guide or setup CD that came with your router, or you can download a user guide from Netgear's technical support page (see Resources). Most Netgear routers use one of the following addresses: http://192.168.1.1; http://www.routerlogin.net; or http://www.routerlogin.com. Press "Enter" or click "Go" in your web browser after you have entered the address.
  3. Enter the router's username and password. A prompt will appear on the screen when you enter your router's address, requiring you to enter a username and password before you can access the router's settings page. The default username for Netgear routers is "username" and the password is "password." Because the textboxes are case-sensitive, you must enter both of these using all lowercase letters. Press "Enter" to log in to the router and begin changing its security settings.
  4. Open the security settings menu. The router's home page has multiple links for changing settings. Find and click the "Security Settings" link to change the router's security settings.
  5. Change the SSID, choose an encryption setting and create a password. The default name (or "SSID") of your wireless network will be "NETGEAR." Enter a new, memorable name for your wireless network to help detract would-be hackers from trying to access your router, as most novice computer users with unsecure networks do not know how to change the default network name or institute any other security features. Newer Netgear routers offer WPA or WPA-PSK encryption to secure your network, both of which provide high levels of security. Select either of these. encryption types and create a unique password. This will require all users to enter the password before they can log in to your wireless network. It is important that you create a complex password that has several characters, including numbers. Once you have created a password, click "Confirm Password" to save it. To exit the security settings menu and log off of the router, click "Save" or "Apply" to save the changes you made, then click "Logout" to exit the router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Read more: How to Set up a Secured Wireless Network on Netgear
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 25, 2010 | NetGear KWGR614 Router
How do i create a password for my netgear router. i never set up a password and someone has been doing dowloads so i need to go back and setup password so this will not happen again.
You need to log in your router as administrator, then go to wireless security in that you can configure your wireless password then save and reboot your security password will configure more details mail me at [email protected] Thank you
Aug 25, 2010 | NetGear WGR614 Wireless Router
How do i secure my wireless network??
Go to the computer that the device is connected to. and use the following link:
http://kb.netgear.com/app/answers/detail/a_id/12873
YoAlternately use Internet Explorer; do this.
Apr 12, 2010 | NetGear WGR614 Wireless Router
Did a factory restore, set up wireless, can browse internet via a neighbours unsecured network, but cant on mine. can log in to router wirelessly but thats it no internet
Dide you set up the wireless on your router? If you have done this and you have it set for None for security, you will also be "unsecured", BUT you still have a name (SSID) to identify your network. Check that your internet is set for "Private" access, if you are presented the option between Private and Public.
Nov 16, 2009 | NetGear WGR614 Wireless Router
Wireless router connection problems
That is very possible. I would reset the router by reset switch on back. Also both routers will tend to build up a static charge loosing the connection. You can unplug it for 10 seconds and replug in.
I would also try setting up new home network using automatic settings.
Jun 23, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Want to secure the site
First off... a manual will help you understand your options alot easier so here is a link to it: http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf
You did not say specifically but I assume you want to set up wireless security. This is set in the router under wireless security and you have a few options. You can use WEP or WPA security. Either one would use a passphrase. This is set on the router and on your pc. I would also suggest doing a bit of googling on wireless security basics. It will cover not broadcasting the SID, using mac filtering, WPA and WEP security.
Good luck and thanks for using FixYa
Mar 24, 2009 | NetGear WGR614 Wireless Router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
Wireless connection of netgear wireless router for compaq laptop
Sometimes firewalls on your computers can cause connection issues. I had the same problem with my home network. I had norton internet security 2008 on both systems, but the firewall settings on both computers had to be adjusted to allow the computers to talk. If you have different brand firewalls on each computer, you should consider to switching one of the computers so that it matches the other.
Another thing you want to do is log into the router's web utility and check to see if the wireless settings are blocking wireless connections in some way. You also want to make sure the ssid broadcast is enabled.
Finally, you really should consider using security on your router, so wireless connections would be password protected. I suggest wpa personal.
May 03, 2008 | NetGear WGR614 Wireless Router
Netgear router WGR614
try using "admin" for the user and "password" for the password. I have this very same router and that was the default settings for me.
Nov 19, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Router Logo
322 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
