Question about ASUS US P8H67M PRO Desktop Motherboard Intel Socket H2 LGA1155 HDMI 10 Onboard USB Ports (B25P8H67MPROCSMR3112
Processor overtemp BIOS says that it's 190 degrees Fahrenheit at boot-up. Processor fan working properly at about 1927rpm.
  • 2,878 Answers
Check the heat sink / fan ASAP. The tempature is extremely high and may cause a critical hardware failure. You may even need to replace the CPU fan.
Posted on Dec 31, 2012
SOURCE: pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Posted on Sep 12, 2008
map9966
  • 2351 Answers
SOURCE: Does not boot
To exclude a possible short, remove the MB from the case and place MB on to a couple phone books thats covered with a non static MB bag. Connect power supply, keyboard, mouse, primary hard disk drive, monitor and internal speaker. Also leaving CPU/heatsink assembly and memory connected.
Short the power-on pins by using a pen. See page
1-34 in you're manual, PWR BTN. If the system boots ok than there was a short with the MB while in the case. If the system does not boot than the MB is bad or the bios needs flashed. Keep the MB out of the case and follow the instructions on page 2-2 section 2.1.1
Link to Asus; http://usa.asus.com/Search.aspx?SearchKey=P5RD1-VM
Hope you find this helpful!
Mike
Posted on May 09, 2010
  • 1027 Answers
SOURCE: Boot time show CPU Fan Error but no need to F1
Replace the CPU fan.
Posted on May 27, 2010
yegarboy
  • 286 Answers
SOURCE: unknown processor
You need a bios update. Go to your PC's manufactures website and download the lastest bios update. If your not sure as how to do this please leave a comment with your PC's make and model and i will gladly direct you with a link. :)
Posted on Jul 01, 2010
Testimonial: "thanks"
joecoolvette
  • 5660 Answers
SOURCE: RE ASUS P5S800-VM Motherboard.. system will not
Bad Power Supply. Weak voltage power rail.
[There are three main power rails in the SMPS for your desktop computer.
A) The 3.3 Volt power rail
B) The 5 Volt power rail
C) The 12 Volt power rail ]
1) ALL of the LED lights on at once use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Just depends on what Processor it.
Remove the Processor, and you will have power to light LED lights, and spin fans.
Of course without a Processor operating, you have No computer.
Replace the Power Supply.
Do you have a KNOWN to be good, Compatible power supply available to use for a test unit?
Need guidance in replacing, or suggestions for Power Supply's to choose from, post In a Comment.
Regards,
joecoolvette
Posted on Dec 02, 2010
Have a desktop windows 8 model 110-023w I get message about Fan Not Detected and have to hit F1 to boot
This is self-protection message from the BIOS/CMOS. It is stating that it is not detecting the presence of a CPU fan (no rotation). Thus it is not starting the processor to prevent overheating. If you F1 the system you will force the processor to start, it will overtemp, and then shut down automatically anyway. You need to check the CPU fan and repair.replace as necessary.
Jan 11, 2016 | HP Pavilion Computers & Internet
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
Hello all: Still have this problem. Anyone out there able to fix this problem? Sony VGN-NW160J 4 gig ram 340 gig HD Screen will not come on. Will not boot, cooling fan spins, and hard drives hums and...
remove the computer covers remove the memory from slot and clean the memory with clean soft clothalso remove the processor fan from the socket clean the surcace of the heatsink and the processor and apply thin layer of heatsink solventand fix the processor fan firmly on the processor socket
Jan 15, 2011 | Sony Computers & Internet
Acer won't boot up
Are the cooling fans working underneath
If they have stopped the processor will shut down
If it happens on a frequent basis you can cook the processor
Feb 12, 2010 | Acer Extensa Laptop
My sony vgc-rb40 will not boot bios with cpu fan connected
mostly all fans are 12V DC try connecting all the fans directly to SMPS of the system i.e the red and the black wire
Sep 16, 2009 | Sony VAIO VGC-RB40 PC Desktop
My bios shows system fan speed as 0. It seems all fans are working, but i keep getting temp alarms. any ideas? I can see a fan at the front, one at the back, one CPU fan, one graphics card fan & two...
See (in the CMOS SETUP ) if the processor temperature is between 30 and about 50 degrees celcius. If it is way above that then the thermal paste between the fan and the processo has hardened and the contactbetween the processor and the fan is POOR . Replace the paste withy NEW paste. (a thin layer) That usually sorts out that problem.
Aug 03, 2009 | Computers & Internet
HANG UP PROBLEM AND NO ANY FUNCTION WORK.
open the laptop. remove the cover.its a little tricky. still you can do it with proper tools. now reconnect the processor fan, and the pheripherals you can. look for bios jumper JP13. reset the bios or cmos. plug in the charger and then switch it ON
Jul 04, 2009 | Computers & Internet
Intel D865GBF hangs for error thermal event
The solution to your problem can be found at this webpage : http://www.intel.com/support/motherboards/desktop/sb/CS-012552.htm.
It guides you on how to solve overheating problems. Personally I think you need to unseat your processors and refix after cleaning and applying a fresh coat of the Heat Conducting Paste and re-seat it very, very carefully. Gently in the beginning and once u are sure that it has got into its slot smoothly then press harder until u hear two cliks, like a double lock. Fix the Heat sink &see that the retaining clips are snug tight. Try it & post the results........sodeep
Quote "High Temperature Alerts
If Intel Active Monitor or Intel Desktop Utilities alerts you about temperatures above set thresholds, there are a number of steps you can take.
Check for proper airflow:
  • Make sure the processor and chassis fans are running.
  • Check the cabling; make sure cables are not interfering with proper airflow through the chassis.
  • Check that nothing is blocking airflow into and out of the chassis' airflow vents. This is common in direct airflow systems (BTX). Chassis manufacturers may apply a dust filter in front of the CPU fan inlet. Check that the filter is clear and free of dust buildup.
  • Make sure that the air intakes for the external fans are unobstructed and are located at least several inches away from walls and other items.
  • Make sure that the power supply fan is running properly and any other external case fans are running properly.
  • Consider adding another chassis fan.
Other troubleshooting steps:
  • If your PC uses an Intel® Pentium® 4 processor in the LGA775 package, be sure the heatsink is properly installed and 'locked'. Pay particular attention to the proper orientation of the locking pins and give a good push down on the pins (sounds like a double click) to lock them into place. For complete processor and heatsink integration information, refer to Boxed Processor Installation.
  • Verify the chassis/case and power supply are appropriate for the processor model and frequency and the motherboard you are using.
  • Verify the thermal solution for the processor is adequate for the processor and frequency of the processor.
  • Make sure the processor fan cable is connected to the correct fan header (specifically for the processor). Refer to your motherboard documentation for more information.
  • Make sure that the thermal interface material or the thermal grease is applied to the processor properly.
  • Update the system BIOS to the newest version. This will often correct problems with how the system measures temperature.
Fan Control Behavior Changes after BIOS Updates
After updating to the latest BIOS version on certain Intel Desktop Boards, the CPU fan may not go to full speed operation until the processor reaches about 72°C (162°F) and all system fans go to full speed at 75°C (167°F). You may see temperature alerts in Intel Desktop Utilities.
Previously, certain processors' thermal values were not available to the BIOS so the BIOS was unable to perform the appropriate fan control (the fans ran at 100% constantly). With recent BIOS updates, the thermal values are available and the BIOS will run the appropriate fan control. This means the processor may reach temperatures of up to 75°C (167°F) before the fan will go to full speed. The fan control now allows processor temperatures to rise to optimal levels while the slower fan speeds improve acoustics.
Setting Temperature Thresholds in Intel® Active Monitor or Intel® Desktop Utilities
By default, the temperature thresholds in the hardware monitoring software are set as follows: Zone Intel® Active Monitor
Intel® Desktop Utilities (ver. 2.0.11.46 and earlier)
Intel® Desktop Utilities (ver. 2.1.8.63 and later) Processor 75°C
(167°F)
75°C
(167°F)
75°C
(167°F)
Zone 1, Zone 2, or Motherboard Zone 50°C
(122°F)
50°C
(122°F)
65°C
(149°F)
If you've checked for proper airflow and performed the other troubleshooting steps listed above and you still consistently receive high temperature alerts in any of the temperature zones:
  • If you are using Intel Active Monitor, you may increase the temperature threshold. You can safely increase the Zone 1, Zone 2 or Motherboard Zone threshold up to 60 Degrees Celsius (140 Degrees Fahrenheit).
  • If you are using Intel Desktop Utilities version 2.0.11.46 or earlier, upgrade the software to the latest version, which sets the zone default thresholds to 65°C.
  • It is not recommended that you increase the Processor Zone threshold.
Downloading these utilities:
Intel Desktop Utilities".........unquote"
Feb 19, 2009 | Intel D865PERL Motherboard
Booting
A computer hanging when it has boot could possibly be associated with: -
1. Processor Overheating
2. Corrupt Operating System.
3. Corrupt RAM
Recommendation.
On the first instance, when the computer is booting, if you can switch to the BIOS setup and check the system health, you could find that the temperature could be more than 60 degrees celcius.
To solv this, ensure that the cooling fan is sitted properly on the processor.
Ensure there is no dust on the fan as this could slow down the rpm(revolutions per minute) or try changing another fan.
As for the operating system, you can trying loading or repairing the existing operating system using the right source.
In some cases where RAM is corrupt, trying using another chip to be sure if the problem is being caused by this.
Good luck.
Jun 21, 2008 | QDI Group QDI Advance 10F Motherboard
Cpu fan stopps
try to clear cmos with the jumper next to the mainboard battery
hit delete enter setup bios and save changes
chek if the main board is not in unapropriate contact with the metal case.
chek the fans power connector pins in the board
and finally make sure that ur power supply is functionong properly.
Nov 14, 2007 | Computers & Internet
ASUS US P8H67M PRO Desktop Motherboard Intel Socket H2 LGA1155 HDMI 10 Onboard USB Ports (B25P8H67MPROCSMR3112 Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
