Question about Home
American Standard 4260 Fill Valve won't flush
SOURCE: american standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Posted on Nov 23, 2008
  • 6 Answers
SOURCE: Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Posted on Mar 14, 2009
co7196
  • 3433 Answers
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
  • 3 Answers
SOURCE: we have american standard toilet model 4260 that
My husband and I have this toilet, it apparently has many complaints along the same lines. We just called American Standard and they're sending out all new parts for inside the tank.
Posted on Dec 18, 2009
VOCAL FILLING american standard 6 ltr flush --when the last half of the tank is filling ,it becomes quite vocal , like a loud hum ! any ideas ?
What probably is happening is the valve in the fill tube is warped or worn. The easiest fix is to replace the fill valve with a new fluid master. This is where your noise is coming from.
Feb 20, 2013 | American Standard Antiquity/Repertoire...
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
Toilet takes a long time to fill up after flushing
Perhaps the shut off valve is not fully open, or constricted. Try opening and closing the shut off valve to loosen any sediment. Otherwise, replace shut off valve.
Sep 14, 2012 | American Standard Home
We have 3 toilets in the house. the tanks won't refill after flushing
You may have dirt getting into your water from the well and clogging the fill valves in your toilets. Valve assembly can be opened and cleaned out from the top. Instructions are available on AS website for your model. (Note) If you are picking up material from your well, a sediment filter should be added to your water line.
Apr 15, 2012 | American Standard Home
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
Toilet flushes intermittently by itself.Water leaking into bowl.flapper and float valve seem to be okay.This is a hamilton 2092.
Check the fill valve. it may have a bad seal inside or some trash in the water supply (iron or calcium deposits) may have clogged it. Do you hear water running when it's not flushing?
May 27, 2011 | American Standard Home
My American Standard toilet flushes okay but when it is filling up the water will not stop running unless I lift the top and depress the lever.
Replace the fill valve. You can pick one up[ at Home dep or Lowes for about 20 buks. Close your angle stop at wall behind toilet. Drain all water from tank then remove supply loine from under tank. Then unscrew fill valve and remove gasket and all. Remember to put gasket in new one. :)
Sep 07, 2009 | American Standard Colony 2388.012.222...
Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
Aug 01, 2009 | American Standard Traditional Champion4...
Jun 15, 2009 | American Standard Home
Home Logo
97 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
