Question about Honeywell LYNX Touch - L5000 LYNX Touch Touchscreen Color Graphic Wireless Self-Contained Security System
Honeywell LYNX Touch - L5000 does diagnostic but will not load touchscreen interface
Tried to add new motion sensor, would not let me in to section even with password. decided to cycle power, plugged it in and it only does diagnostic check, everything fine according to check, but the screen goes white. no interface. tamper switch intact. tried several times with battery disconnected and no luck. checked inside for loose parts,chips and cards.everything in place and secure.
Therinnaiguy
  • 1420 Answers
SOURCE: heat will not turn off
Call 1-800-341-0110, Honeywell Residential tech service.
Posted on Nov 15, 2007
Benimur
  • 6966 Answers
SOURCE: Dy/night heater turns on for 10 sec then and off, over and over
Hi and welcome to FixYa,
If I understand your concern, it is that the heater switches itself on for 10 seconds and then switches itself automatically off. A couple of ideas of you may want to explore/check:
  1. the built-in protection system detects an internal fault and to prevent any further damage switches itself off;
  2. the faults could be:
  • open heating element (assuming it is electrical);
  • blower not turning;
  • open limit switch. The limit switch is an inline cutoff to the heater that automatically opens up when the heater exceeds a pre-determined temperature independent of the settings in the thermostat. This is like a thermal fuse once gone bad will remain open;
  • whereas a thermostatic switch will turn on if temperature is below its threshold and turn off if the temperature is above. It is basically an on/off switch.
Often the limit switch would look like the image below.
To be able to provide a more detailed information/assistance, pls verify & post back the model number of the Day Night Heater. Model 8ou-19 does not turn up anything. Or perhaps you can share the website you were referring to.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 21, 2008
james3751
  • 614 Answers
SOURCE: A/C won't kick on w/ Honeywell RTH230B
Make sure you jumper R to rh. Russ
Posted on Jul 31, 2009
  • 10 Answers
SOURCE: Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Posted on Oct 17, 2009
heatman101
  • 43501 Answers
Okay it seems that for some reason the battery change scrambled the brain of the t-stat... that happens...
To fix it you will now have to go into the "Installer Menu" and reset the paramenters of the t-stat.
If you have the Installe brochure then you can look in there and then set the tistat for "heat/cool" and also to "auto fan" and then to "auto changeover" These should get you back to cooling again...
No big problem, just a small programming issue...be patient and if you do not have you book don't worry... you can look it up here...this tip tells you where and how to find any of the Honeywell t-stat manuals.
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Posted on Aug 21, 2010
Lynx touch stuck in arme away -bypass
At the bottom of the touchscreen there should be 4 tactile buttons. One looks like a pyramid with an ! in the middle, one looks like a house with a person standing outside, one looks like a padlock that's unlocked, and the other one looks similar to an old style alarm system keypad. If you press the button with the icon that looks like the open padlock, the screen should come up and give you the option to enter your 4 digit code to disarm the system. Enter your 4 digit security code and the system should disarm. If this doesn't work, or if you don't know the valid security code, you should contact an alarm dealer for service.
Apr 27, 2014 | Honeywell L5100PK - Lynx Touch 5100...
How can I add security cameras to my lynx alarm system
You cant. Upgrade you system to Ademco quick connect and if you have ADT add "Pulse". 0ed4b61b-897e-406a-8611-aad951c95dd8.jpg
Apr 13, 2014 | Honeywell Home Security
Dell laptop touch screen not working
Check all drivers are loaded for the touchscreen interface, if they are remove them and re-install.
If that doesn't solve your issue I would check the cable that connects the touchscreen and that the touchscreen is fitted correctly.
Mar 12, 2014 | Dell Inspiron 7000 series Laptop Universal...
PIR Sensor problem
This is normal. it takes several minutes after power up to adjust to the environment that it is in. Then the motion will only transmit a signal to the alarm panel every few minutes. This is to conserve battery life. Let it sit idle for more than 3 minutes after arming (do not trip the sensor during this period). Afterwards, the first trip should be instant and that should be all you need.
May 28, 2013 | Honeywell | Ademco LYNX Plus LYNX Plus
How do I lower beep volume on honeywell lynx plus?
Your four digit code, volume then the down arrow key.
Aug 29, 2012 | Honeywell | Ademco LYNX Plus LYNX Plus
Honeywell Lynx plus L3000 wont dial over VOIP
Apparently it's an issue with contact ID, if you set it to 4+2 it should work. I will be attempting it this week, I will try to update with my results.
Jun 21, 2012 | Honeywell Lynx Plus Wireless Alarm Kit
Can I hot sync z22 palm without the touchscreen?
The data on your old Z22 is very likely very secure, and the touch screen problem is very common - there are a few tricks to get the touch screen working long enough to transfer the data.
I have a web page entirely for maintaining, repairing, and interfacing your Z22 at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
You can try these tricks, or just replace the screen for $9 U.S., since the screen only needs you take the unit apart and flip open a connector lock ...
I would strongly advise getting a solid plastic cover over your new Z22, since this is the key to keeping the screen working...
hope the information is of help to you
good luck
robin dusty graves
Z22 PALM PILOT hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-0.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-1.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-3.jpg
Nov 06, 2008 | Palm Z22 Handheld
Honeywell LYNX Touch - L5000 LYNX Touch Touchscreen Color Graphic Wireless Self-Contained Security System Logo
154 people viewed this question
Top Honeywell Televison & Video Experts
Ron Durham
Tom Chichester
Are you a Honeywell Televison and Video Expert? Answer questions, earn points and help others
