Question about Hotpoint Aquarius WMA42 Front Load Washer
Does the draw compartment come out inside
Ive taken the draw out of my aquaruis machine but want to clean inside? do they come apart
  • Hotpoint Master
  • 3,463 Answers
Remove any parts that you can in the drawer itself ,and thoroughly clean all pieces., and poke wire through syphon tube, to make sure it is clear.
In the drawer compartment get a stiff nylon brush and clean all the inside out as best you can, particularly the top of the compartment.
Plz rate my solution.
Thanks.
Posted on Jan 18, 2009
Hi ive tried everything but the draw still wont open on my dolce gusto can you help please
If something is broken inside, it will need to be taken apart for repair. Before that, try the following:
  1. Unplug it.
  2. Move the selection lever from cold to hot and back several times. Be sure the lever will move full stroke smoothly. Put the selection lever in the center position.
  3. While firmly pulling the draw outward, "snap" the draw upward.
If that does not work, it will need to be disassembled.
Feb 01, 2015 | Krups Dolce Gusto KP 2100 Espresso Machine
Softener wont add
Please ensure the machine is turned off at the power socket before you do anything.
Have you tried removing the draw? If you pull the draw out on most washers and slightly tilt the draw up and then try and pull further out the draw will come out. (DO NOT USE BRUT FORCE) if it doesn't come out easily then it probably isn't designed to.
If you get the draw out give it a really good wash in hot soapy water, the compartment where the softener goes normally as a piece of plastic that lifts up so you can clean the compartment throughly. Whilst the draw is out also give the inside of the draw compartment a clean out. (PLEASE ENSURE THE POWER IS OFF) Just for safety.
Once you have cleaned the draw replace it and try a full wash and see if that cleared the problem.1_15_2013_10_08_16_pm.jpg
Jan 15, 2013 | Belling SGE12X Front Load Washer / Dryer
Softner is dispensed in Wash cycle
in the top of your soap draw compartment is a lever that switches the water jets over ( for instance on the main wash the jet arm is directed in the main wash compartment which will take away your main wash powder then it moves the jet are to the sofner compartment on the final rinse ) the jet arm somtimes jams and needs cleaning and the small holes above your draw compartments clog with lime build up the thing to do is take out your draw clean the inside at the top where the holes are and take the top off your machine there are two screws at the back top you will see the little ark on your soap draw it will have a return spring on it gently move it from side to side this will clear any obstuction make sure that it will spring back clean any line around the arm ( make sure you switch unplug your machine before you remove the top)
Nov 21, 2011 | Washing Machines
The softener and bleach compartments are always filled with water. Also, the dispenser drawer is VERY dirty. How do I remove the drawer to clean it?
I have the exact same problem. Ive taken the hoses beneath the drum apart in case it is backed up all the way to the dispenser. Found a bra wire and removed it. Ran another cycle - still the same problem with water in the dispenser - even running down the outside front face of the washer. Not sure what to do next?!?!?!
Nov 06, 2010 | GE WSXH208A Front Load Washer
The softener is not dispensing, most of it, it's staying in the compartment.
It looks like you need to clean the draw out to remove there should be a clip at back top of draw you push down on clip and pull draw out. after this you can clean out all the draw and where the softener compartment is it should come apart. to put draw back in just slot it back in. Hope this helped.
Sep 20, 2010 | LG WM1815CS Front Load Washer
Problem
remove soap draw and strip apart as it is in need of a good clean as the liquids are taken by a syphoning process so the draining holes are clogged.
Dec 22, 2009 | LG WM-2277HW Front Load Washer
No fabric softener being taken from the draw of washing machine
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 01, 2009 | Hotpoint WMA54 Front Load Washer
Hotpoint wma46, my machine does't seem to be taking/emptying the condition during the cycle, i have taken the draw out and cleaned it but it still won't work properly any advice ??
Hotpoint wma46 This video will show you how to keep your soap draw clear and how to service the parts
Jul 08, 2009 | Hotpoint WMA46 Front Load Washer
Bobbin thread getting caught
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Mar 21, 2008 | Singer 3962 Mechanical Sewing Machine
Washer Softnener dispenser
remove despenser drawer, by pressing down plastic tab and pulling drawer towards you, use hot water and old toothbrush to clean all compartments, the softer compartment can come apart to clean, use knife or flat screwdriver to take apart .good luck eire.
Dec 07, 2007 | Frigidaire GLTF1670A Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
61 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
