Question about Whirlpool LHW0050PQ Front Load Washer
Ariston AVTF 129 a problem with code F 02 which stop the program
The code F 02 stop any programs and I can not use the washing machine. The roll it was blocked with the door down.
  • dan_eugen_te Jan 18, 2009
    The pomp is working, but is possible to don't work the motor, because the roll don't turn and for that the open door don't come back in higher part of the washing machine
  • Anonymous Mar 19, 2009
    I have the same problem error F 02, and it does not finish the washing
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: The Ariston ATVF 129 wash machine do not work and post F-02
F02 is a indication that the motor has jammed, and or the tacho has come loose or broken.
The tacho is the magnet at the end of the motor away from the pulley., check this first, you may have to have a new motor fitted.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
What does the error code 07 in an ariston amd 129 ?
the led flashes seven times? then pauses for 8seconds? this is how you determine the service code on a 129 there isn't a F7 code on a 129 on a 125 it's a heater relay stuck.... hope this helps~~
http://appliancejunk.com/forums/index.php?action=dlattach;topic=8959.0;...
Jul 15, 2014 | Washing Machines
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Ariston avxl 129 washing machine has stopped working.
This washer does not have a good track record. There are many many complaints out their on this brand in general. It is also not a cheap purchase.
1st. Suspect is the mother board followed by the motor.
Nov 20, 2011 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Washing machine programme knob has been pushed into machine
Turn the D Shaped spindle with a pair of grips until your machine will do a spin cycle only .
When it can do that put the knob on the shaft with the marker on the knob pointing to the mark on the facia saying Spin
Jun 05, 2009 | Washing Machines
Thanks.
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
788 people viewed this question
Dan Webster
Dan Webster
Sal De
