Whirlpool washer moves across floor on spin cycle
    Sergeant:
  • 475 Answers
It might be that your load is off balance. try to keep it balance with your load.
Posted on Dec 31, 2012
SOURCE: neptune washer walking across the floor
We have no complaints about the maytag neptune, except that it walks across the floor. My wife just called Maytag at 866-616-2601 , and was treated great, they are sending some parts to fix the problem, free of charge, and we are to get them installed free of charge when parts arrive. When you call that number, ask for someone who specializes in the vibration problems. Our maytag neptune is model # mah8700aww.
Posted on Feb 27, 2008
  • 1028 Answers
SOURCE: front load washer- spin cycle is like a hurricane
be sure all the shipping materials have been removed ..next adj all feet up as close to bottom of washer as possible ..try rocking machine ..if movement detected adj only foot necessry to firm up washer ..still have vibration suspect floor ..front washers need a good SOLID floor
Posted on Aug 17, 2008
ngfam1
  • 639 Answers
SOURCE: washer moving while on spin cycle
Friend,
ngfam1 At your service!
The washer should be leveled with a spirit level.
If it is not corrected after this measure!
remember you have a full warranty for one year and they will come out a remedy the problem with hands on service! for FREE!
Then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool top loading washer, spin cycle just quit.
From the symptoms you describe, it sounds like you may have a broken motor coupling. The coupler is located between the drive motor and gearcase (transmission). It takes the place of a drive belt. This configuration is known a "direct-drive". The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
Replacement couplers are improved and more resilient to resist breakage. The part number is included in the link I provided. You can purchase one at appliancepartspros.com for about $11.
If you have any questions about this repair, please let me know. I hope this helps you.
Posted on Dec 07, 2009
localwonder
  • 6784 Answers
SOURCE: washer tub vibration on spin cycle
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is istalled.
Posted on Jan 01, 2010
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
What would the cost be to tighten drum in washer
Sounds like the concrete weight is broken. It stabilises the unit while spinning.If the drum moves inside the tub, the bearing has collapsed
May 09, 2012 | Whirlpool duet Washing Machines
The tub is very wobbly and the machine was loud and moved across the floor when the spin cycle was on
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Unit shimmy's across floor
Remove the two support bars from below the washer drum from the front as instructed in the installation manual
Jan 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
My bosch washing machine keeps moving across the floor - we have tried to balance but on the spin cycle - it still moves
either ur drum is loose or ur floor is realy bacd. Dont forget that most macianie have adjustement screewed
Nov 19, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Sep 19, 2008 | Admiral AAV7000A
Front load washer- spin cycle is like a hurricane
Aug 16, 2008 | Washing Machines
Severe vibration on spin
tilt the machine back and check that the blue clips that secure the suspension legs to the base are in place and both the legs are secured top and bottom.
Dec 18, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
