normally error like this disappear when a hard reset is performed? did you leave the unit turned off by plugging out from wall power for one night ??
The F11 fault is a fuse blown on the circuit board.
Apparently this fuse failing can blow the board so you may have to change the board if needed. The board is located at the back of the machine so you need to take the back off, unplug the board, change the fuse which you can buy at Maplins and put the board back.
If it works fine, if not then you need a new board. Hope this helps you.
First make sure machine is turned off.
Second press & hold temperature button .
Thirdly press the on button & hold at the same time as the temperature button.
Fourthly release the 2 buttons at the same time .
Fifthly press the soil button .
Sixly turn machine off then back on & F11 message saying fault F11 must disappear.
if not try this process once again. if the error is not cleared then you will have to do as i have said you earlier.
Comments:
Jan 18, 2009
- also try this
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work. Jan 18, 2009
- hope it helps ill appreciate a fixyaa rating
