Brother MFC-665CW All-In-One InkJet Printer Logo
Posted on Dec 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i copy double sided?
I have a 9 page pamphlet that I need to copy but don't know how to copy double sided.
Jim Dowell
Level 3:
Master:
  • Master 345 Answers
  • Posted on Dec 31, 2012
Jim Dowell
Master
Level 3:
Master:
Answers
345
Questions
0
Helped
121451
Points
1057
Your Printer does not have a 2-sided(duplex) printing feature, so you cannot print on both sides of the paper.
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
I don't know how to change from double sided printing to single sided
Is your computer running a Windows OS or is it a Mac?
Under Windows, after you press Print in your application (word processor or other program), press the Preferences or Properties button on the pop-up window. (The button title will depend on your version of Windows. It could be labeled as Advanced in some versions of the Canon software.)
Go to the Page Setup tab and uncheck the Duplex printing box. (This is the third section of the window.) Click Apply and then OK.
For the Mac, the setting is on the print dialog pop-up. It's a drop-down menu.
I hope this helps.
(Under some versions of Windows, you can also adjust this setting from the Printer Properties in the Hardware & Devices (Hardware and Sound) Control Panel. Right click on the printer and then select Properties to get the window to open.)
2answers
Changin forwarding address from my fax machine
I don't know this exactly machine type.
Please check this extended manual:
http://pdf.superwarehouse.com/specs/Canon_1735B002AA_manual.pdf
Maybe you can get your answer here.
4helpful
2answers
Hi. I have a Canon IR2018 printer in my office. Because I am eco-wise I would like to set it from single to double sided printing (I think that's the term for printing on both sides of the paper) but...
you can do so if your machine has a duplex unit attached.if it has a duplex unit then for printing you have to select 2 sided profile as default or for prints when u want double sided from you pc print software(canon) or the server if you have one .that way u will get all the prints in 2 sided. for copying u have to select 2 -2 sided by pressing the 2sided key on the console of the copier.then place the originals in the ADF and thats all
2answers
Hi. I've moved to a new home with a Stoves 720EF oven. I was find last week but now I cant make it work at all. I think it is on automatic but I dont know how to turn that off and don't even know...
If the oven is on automatic, a small 'A' will appear in the clock window. To remove this press the second and third buttons from the left simultaneously.
If you need more information, supply an email address and I will send you a pdf copy of the handbook.
1helpful
2answers
How to set a MG5220 printer to do 2-sided copies?
The Canon MG5220 has a built-in auto duplexer and can print 2-sided documents. On a Mac, click print, and in the print dialog box select Duplex Printing & Margins (drop down options below Printer and Presets). Check the Duplex Priting box, and selected the Stapling side. Then click Print. That's it!!
How can double sided print
HP3350MFP - Duplex Printing/Copying
Hello, The HP3350 does not support automatic double sided printing. The HP3390/3392 printers support this option. In order to double side on the HP3350 a manual duplex will need to be conducted, which means running page 1 through the printer, flip the page over and print page 2 for the reverse side. It may be necessary to experiment a few times to achieve the proper printing orientation. You can download a copy of the users guide from the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=ca&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=1161389
4helpful
Double-sided copy output
In print dialogue box there will be a setting for long or short edge binding, associated with duplex printing. Find it and try it. Good Luck.
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Norman Weimar
Norman Weimar
k24674
