Question about Electrolux Frigidaire Professional Series 30" 1.8 cu. ft. Microhood
Frigidaire electrolux oven door locked unexpectedly and now won't open, F1 Error code
"Door Locked" light flashes and every 15 - 30 seconds oven Beeps and "F1" flashes. Turned oven off at power source for 20 minutes, still no luck. Problem is there is food in the oven.
  • John Dec 31, 2012
    THis is not a microwave ... not sure how this got labeled as such, it is an electric oven
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: AEG Fault code E202
I would suspect a bad door switch or door switch mount, or possibly a bad electrolytic capacitor on the control circuit board.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Beyond that, I could only speculate, since I don't have experience or information on AEG products.
Posted on Jan 10, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave was closed too firmly and will light up but not heat
See this file on door switches.
Posted on May 30, 2010
  • 6771 Answers
SOURCE: food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Posted on Mar 16, 2012
Why my door on my frigidaire microwave model GLMB209 won't open?
Good Afternoon Friend,
I understand that the door will not open on your Frigidaire microwave, model# GLMB209. Specifically, when dealing with your microwave, I suggest contacting your local authorized technician. They have been trained on your appliance and will be able to get the door open and repaired, without causing damage to you, your family, or your home. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Electrolux E30MO65GSS Convection Microwave...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have a frigidaire Electrolux gallery series glmv168cqi microwave. The timer counts down, but the oven doesn't turn on. Sometimes when you open the door the fan turns on.
That would be a failing bottom door switch, or its mount.
My help file on door switches is here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
There's a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the control panel has been removed, you can access the door switches for testing and possible replacement.
There should be a technical manual hidden behind the controller or grille, too.
If you need further part ordering help, contact Electrolux:
USA
800•944•9044
Electrolux Home Products
North America
P.O. Box 212378
Augusta, GA 30917
Canada
866•213•9397 (English)
866•294•9911 (French)
North America
6150 McLaughlin Road
Mississauga, Ontario, Canada
L5R 4C2
Apr 22, 2013 | Microwave Ovens
MY OVEN DOOR REMAINS LOCKED AFTER CLEANING. I GET A F1 DISPLAYED. I LEFT IT UNPLUGGED ALL NIGHT AND IT STILL SAYS THE SAME THING AND IS LOCKED. IS THERE ANYTHING I CAN DO?
I could be more specific with a model number from the range.
The F-1 code on most ranges is a bad electronic control board. The oven lock is controlled through this board.
If you replace the board you should be able to open the oven.
You may also have a blown thermal fuse behind the rear panel on the oven as a result of self-cleaning.
Self cleaning is a nice feature but is not recommended by appliance repair technicians.
Sep 04, 2011 | Maytag Microwave Ovens
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
Jan 13, 2011 | KitchenAid Microwave Ovens
AEG Fault code E202 On opening the door of my microwave combi oven the interior light flashes accompanied by what sounds like a relay chattering and the display flashing between the normal display and...
See:
Jan 09, 2010 | Electrolux Microwave Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Electrolux Frigidaire Professional Series 30" 1.8 cu. ft. Microhood Logo
91 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
