Question about Dell UltraSharp 2707WFP 27" Widescreen Flat Panel LCD Monitor
Attaching a flat screen monitor
I using a regular monitor and flat screen monitor was given to me. Noticed the cable on the reg monitor is a 15 pin conn but pin #9 is not used. On the flat monitor pin #9 is used. Do I need a special graphics card or do I just plug in. I'm using win 2k. In other words trying to figure how to go from a regukar monitor to a flat screen type. Thanks in advance - MB My email is [email protected]
    Genius:
  • 2,985 Answers
Regular connects on the Flat screen just like to the regular plug it in see what you get.
Posted on Jun 23, 2007
SOURCE:
Connect Dell Mini with HDMI to VGA PC flat monitor
hi,
you would need an HDMI to VGA adapter. sometimes it would come in a form of a separate cable or just a regular adapter which would convert the HDMI end to VGA (the blue one that has 15 pins)
you can purchase these cables from your local computer store.
hope this helps
Jul 12, 2010 | Dell Inspiron Mini 10 Notebook
VGA problem with HP monitor
The VGA cable are standard pin out for VGA DB15HD connector.
Learn about it here: http://en.wikipedia.org/wiki/VGA_connector
Apr 02, 2010 | Computers & Internet
I just want basic hook up from my hp compaq to dell flat screen
Most Monitors use the 15 pin cable that is compatiable with almost any computer. I would check the back of your computer for the blue monitor port and then check the cable on the monitor to see how many pins there is.
Feb 23, 2010 | HP Compaq dc5750 Microtower - Free Flat...
Cannot read the model number (chinese) I known i have a flat screen monitor 20 inches from DELL 2004 I want to connect it to my Inspiron 1100 .I need instructions this an handme down so I have no...
Since the cable you're describing is a VGA cable with the 3-row, 15-pin configuration, it will be the 1:D-sub selection. The DVI choice is for HD TV or a display card with HD capability. The S-Video is more commonly used for higher clarity video signals--less than HD of course, but approximately 15% to 20% sharper than a co-axial cable signal. (Reason: co-axial cable has all the color sigs squashed together while s-video splits them out into separate feeds.)
Sep 15, 2009 | Dell Computers & Internet
Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
Apr 13, 2009 | Compaq TFT5015 15" LCD Monitor
Panasonic Plasma Monitor TH-42PWD7B - Convert to TV screen?
hi yvonne not sure if you sorted this but using this lead should get you sorted
http://www.maplin.co.uk/Module.aspx?moduleno=4702
the phono blugs ae used for audio and bnc plugs on the back of your panny are for the video
Apr 04, 2009 | Panasonic TH-37PE30 37 in. Plasma...
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
Connection cords for Acer flat screen monitor
You would need a 15 pin HD D-Sub cable with appropriate connectors model number HD-15. Pls try here or here to view similar products.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Dec 03, 2007 | Acer AL1714 17" LCD Monitor
Dell UltraSharp 2707WFP 27" Widescreen Flat Panel LCD Monitor Logo
77 people viewed this question
Ekse
Clive
Clive
Alun Cox
