Question about Dryers
WHY DOES MY WHIRLPOOL LEQ9508PW1 CONTINUE TO BLOW THE SAME FUSE OVER AND OVER? I HAVE TESTED ALL OTHER FUSES AND THE THERMAL CUTOFF SWITCH AND THERE IS CONTINUITY. THE HEATING ELEMENT IS NEW, I REPLACED IT MYSELF AND I TESTED THE CONTINUITY ON IT AS WELL AND IT IS FINE. i CANT FIGURE OUT WHAT KEEPS BLOWING THE FUSE LOCATED AT THE TOP OF THE HEATING TUBE ABOVE THE HEATING ELEMENT.
protek480
  • 1723 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 12, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
dmftrucker
  • 1922 Answers
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Posted on Oct 09, 2009
SOURCE: Should you have continuity on the cut off switch?
Yes, it should have continuity. You need to replace both thermal cutoff thermostats, the one on the top and on the bottom of the element. Part number 27981.
Posted on Apr 11, 2010
vostendorp
  • 347 Answers
SOURCE: Kemore dryer model110.67522600,
Both the high limit thermostat #3977767 and the operating thermostat #3387134 are normally closed switches and should have continuity. These thermostats are usually replaced as a set because when one fails its often caused damage to the other. The part # for the kit is 279816 and comes with both and is cheaper than if bought separate
Posted on Sep 16, 2010
Whirlpool dryer model LER4634EQ0 won't hear up Cheked the voltage to the dryer, wires to the hearing element and fuses, the hearing element, thermal fuse, thermal cutoff, internal bias thermostat, high...
You seem to have checked everything. Did you check there is voltage to the elements, and have you checked amp usage on elements? Sometimes things check out ok but the problems shows when power is passed through the element itself.
Jan 13, 2018 | Whirlpool Dryers
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Why won't my whirlpool electric dryter #ler4634dqo generate heat?
if you have a old house that has fuses sometimes only half of the fuse will blow making it look like the dryer is working but it wont turn on the heat element take the shielding off the heating element and start the dryer and see if they wires glow red hot when running and also after running the machine does the inside feel warm or cold if it is warm check the duct work on the dryer all the way out to the exit and see if lint is clogging it up
May 05, 2014 | Whirlpool Dryers
I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
Mar 11, 2012 | Whirlpool Dryers
DRYER seems to blow a lot of fuses does one fuse run dryer and the other for heating element? dryer will run BUT not heat up
The typical reason several Thermal fuses(motor circuit) or Thermal cutoff (heat circuit) will go out is because or poor air flow so what needs to be checked it for lint build up in the filter housing below the lint filter and/or a chrushed or blocked venting from the back of dryer all the way to where it goes outside
Aug 26, 2011 | Whirlpool WED5300S Electric Dryer
Everything has gone of on my tumble dryer is there a reset button whirlpool 6th sense awz7814al
Try the thermal cutoff fuse... first check to make sure you have 220 power to outlet and not just a blown breaker. next check power at drier itself to make sure your cord is not bad.. if all is well, check door switch and make sure it clicks like it should.. Next, UNPLUG CORD FROM OUTLET!!!. pull back off drier, and locate thermal cutoff switch, located near bottom on the blower fan housing. locate the thermal cutoff fuse which is usually white in color approximately 2 inches long and narrow with two blue wires, remove and replace approximately $14.95 in Oklahoma. Replace and your back in business....
Dec 20, 2010 | Whirlpool Dryers
IT HAS STOPPED DRYING tHE TECH FIXED IT 3 WEEKS AGO SAID IT WAS A FUSE NOW IT IS DONG THE SAME THING
Hopefully, the unit and the vent tube was cleaned of lint, etc. prior to replacing the thermal fuse. If not, it will likely continue to blow fuses.
Mar 08, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool oven stopped working after self cleaning
If the display still works but neither the Bake or the Broil elements wont heat up, it's likely that the Thermal Cutoff has opened and has not reset itself. This is a common problem after self Cleaning.
The fix is to replace the Thermal cutoff which requres you to pull the oven and remove the back panel to get at the thermal cutoff.
What happens is that in Self Clean, both Broil and bake elements are used and the oven gets so hot that the middle skin (between the oven liner and the back panel, where the thermal cutoff is mounted gets so hot the thermal cutoff operates. It should reset itself but sometimes doesn't and then you have to replace it.
Nov 17, 2009 | Whirlpool RBS305PD Electric Single Oven
Whirlpool GEW9200L not heating up, i have replaced th thermal fuse, thermistor, heating element, thermal cutoff and high limit. What next.
Oct 05, 2009 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
Top Dryers Experts
