Question about Philips MMS171 Computer Speakers
White audio out port not working Properly
The speaker itself works. I've used other speakers on my computer which also work with no problem, on the subwoofer the white audio out seems to be faulty. Once in a while if I wiggle the cord, the sound comes out at the correct volume. I've tried other cords on the subwoofer as well. It seems that for whatever reason the plug isn't connecting enough to get full sound. The sound that I do get from the white port is very quiet. Is there a way I can fix this?
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: hello. I just bought your
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Jun 09, 2011
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
SoundCube Troubles
Like I said run audio through the USB ,RCA ,3/8 audio and the 5/8 audio ports if you get audio it is the one port is bad if all fail it may be the amp. and test the speakers if speakers respond to audio signals from another amp then it is more than likely is the factory amp in the cube that failed
May 04, 2013 | Audio Players & Recorders
Problem getting my bose soundlink to play blue tooth audio from my laptop.
Hi Sirtuan.
Go to the system panel, there choose "sound" . a list with all available sound devices appear. search for your bose soundlink and make it your "standard device".
had the same prob. with my BT headset and this works for me.
if your bose get disconnected the sound should automatically switch to pc speakers.
Regards
Gue.
Apr 06, 2013 | Bose SoundLink Wireless Music System...
I have a sony str-DE695 and I am trying to hook up my speakers/record player to it. The record player has an RCA chord with one white and one black end. The speakers has the same chord but with one red and...
the inputs should be marked phone (if on the reciever the colors are red/white and the colors of the rca ends are black white put the black plug in the red and white plug into the white input..if the stereo doesn't have rca speaker output ports you'll need to cut off the speaker rca's and strip the wires bare then comnnect usually copper (red) silver (white) or pos (silver) neg (copper.
Sep 26, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Problem with Phillips FA 443 Amplifier
I have a similar problem with my Kenwood Basic M1D , C2 setup. Move the input select switch through all of its selections a couple of times, this will clean the contacts and should give you a couple of years more life. Or get the Amp serviced there are some very good small Hi-Fi shops. Incidentally the earphone port is usually a signal taken before the amplifier but after the pre amp so is unaffected by the power amplifier. Unfortunately it could aslo be a failed channel in the amp. These can be repaired or replaced and will be cheaper than a new unit.
Feb 04, 2012 | Audio Players & Recorders
I connected a speaker bar directly to my new LG TV. The speakers came with two audio cables ( red & white) and one video cable (yellow). I connected the red & white cables to both devices - red...
You can only get the television to recognize the external audio when connecting to its audio OUTPUT. If it does not say OUTPUT on the television where you've connected the red and white cables between it and the spear bar it is not going to work. You'll have to connect all your devices to the speaker bar with red and white cables and to the television with a yellow or green, blue, and red cable for video.
Aug 29, 2011 | Audio Players & Recorders
I can't seed to get my speakers to work. I have UBL pro speakers.
1. Check the Audio icon on the task bar if muted. If yes Unmute Go to start > control panel > sound. and make sure that nothing is muted.
2. Sound Diagnosis refer this photo
3. Re install the audio drivers. LINK
4. If steps 1-3 don't work, then take your speaker to your friend's computer and see if it works there? if yes then something is wrong in your computer system, if no, then something is wrong in those devices.
Refer to this image below. From your speaker the 3.5mm jack should be plugged at back of I/O ports LINE OUT.
Thank you for posting hope this helps..
Jul 06, 2011 | Computers & Internet
Can not get my speakers to work
Try to check if the speakers has power and if it is properly connected to the audio port of your computer. Mostly, it is connected to a green port at the back of your desktop. If it doesn't work, try connecting your speaker to the audio green port to the front.
You may also try checking the audio settings of your computer.
Keep me posted.
Thanks.
Oct 26, 2008 | Computers & Internet
Philips MMS171 Computer Speakers Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
