Where i can buy a power adapter for a black series by shift3 20-led utility lantern
4 Suggested Answers
damneddle
  • 1607 Answers
SOURCE: Where can I buy a 6V AC adapter for Emerson 20-led utility lantern?
You can buy those on any electrical shop.
Posted on Nov 10, 2011
  • 12 Answers
SOURCE: Where can I buy the 6V AC Adapter for my Emerson
make usb chharging...
Posted on Dec 27, 2014
deknutson
  • 4 Answers
The Canon AC Adapter from an old camera worked. It was 5 Watt, 6V, & 300mA. I wouldn't invest too much time, or money, however, as unit is not really built to last. Mine made it less than a year. May need a new bulb, but hard to be sure. Mfgr name is not listed anywhere. Product does not show up on Emerson site.
Posted on Nov 17, 2016
How to change the battery for my 4345 coleman lanterne
There are two adapters for that lantern; one for the house and one for 12volt. You simply connect one of the adapters and it will power the lamp and also charge it. Those two adapters came with the lamp; if you don't have them you can contact Coleman to purchase replacements.
Jul 29, 2014 | Coleman 8D Family Size LED Lantern -...
I purchased a lantern model # jasco 17300 and the light quit working after 6mos use
You may get it repaired but the cost will be the same as buy a new one or much more than get a new lambp. So I suggest you purchase one from online store:
http://www.aurabuy.com/outdoors-76-led-ultra-bright-waterproof-headlamp-with-adjustable-band-black-silver-4-aa.html
Mar 26, 2013 | Camping, Backpacking & Hiking
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
How do I change the bulb of the 6V Eveready Lantern?
If it is the yellow floating lantern you have to remove the black plastic stub on the underside of the reflector using needlenose pliers to wiggle and slightly pull until it releases and the bulb will come out.
Jan 06, 2011 | Energizer Eveready Utility Lantern Uses 6V...
Coleman lantern fan am/fm radio
This lantern/fan/radio combination does not use/accept batteries. It is recharged using the black A/C adapter provided with the lantern. I hope you received the adapter with the lantern when you bought it @ the garage sale? You plug the adapter into the little circular opening just above the round spotlight on the lantern. Hope this helps!
Aug 22, 2008 | Coleman Lantern Fan Radio (841.321) AM/FM
Ac power adapter
Both at Walmart and Radio Shack you can find universal adapters that allow you to change the connector and voltage to fit the device. Try one of these, you can usually pick one up for under $10.
Nov 26, 2007 | Computers & Internet
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
