Question about Kicker 11PT10 100W Bass Station Loaded 10" Carpeted Subwoofer Enclosur
I hooked up a Kicker Bass Station into a S10. The sub's red light comes on then when the music starts, it flashes blue/red. Is this because of a lack of amperage from the battery?
  • 631 Answers
SOURCE: my kicker amp turns off
It sounds like you may have the load impedance too low. How many voice coils per woofer? How many ohms is each coil? If you have DVC woofers, are the coils for each woofer wired in series or parallel? Are the speakers wired in series or parallel. Let me know if you need me to clarify anything.
Posted on Oct 05, 2007
Shadowmaru
  • 33 Answers
SOURCE: i turned my 15" L7 kicker and smoke started to come out the box
As stated before, knowing the impedance of your subwoofer would really help the situation. Either way the link I have provided is to your subwoofers manual (Incase you dont have it)
But since you have said it has smoked, if it still works I recommend turning the bass boost down (Bass boost causes alot of heat within the subwoofers voice coil and even within the amp itself and should never be maxed out.)
Here is a link to your manual for the subwoofer.
http://www.kicker.com/sites/default/files/SoloBaricL7Series.pdf
So as a solution to your issue, keep your bass boost turned down. You should almost never need it if you have tuned your amp correctly (You have a very serious subwoofer there)
Consider yourself lucky if your subwoofer is still working without issues.
Posted on Feb 11, 2009
  • 192 Answers
SOURCE: what does sub sonic mean on my Kicker kx1200.1 amp? Do it need to be off or on?
Subsonic refers to frequencies too low for the human ear to hear. Generally humans can hear frequencies in the range of 20 to 20000 hertz (cycles per second), but we hear best in the range of 1000 to 4000 hertz. High amplitude subsonic frequencies can cause damage to your speakers so many amplifiers have an electronic filter in them to reduce the amplitude of these very low frequency signals.
Posted on May 21, 2009
mark24354
  • 776 Answers
SOURCE: my kicker kx 1200.1 keep clicking to protection
Look for a frayed speaker wires. Look everywhere. Start where you can see and then look under carpet, under seats, trunk and everywhere wires go throgh a hole in steel frame. Any minor connection between the two speaker wires will cause high-power systems to go into protection mode. Wires can be damaged by long-term vibrations of your car, people stepping on badly placed wires under carpet, moving seats (when adjusted) or even rodents bitting on the wiring. Look closely and you will normally find it. Also look closely where you connect your speaker wires to the amp. One small strand of wire jumping across to another terminal will cause a short and cause protection mode.
Posted on Nov 19, 2009
Boole5555
  • 160 Answers
SOURCE: kicker subs hook up problems
Connect one to each channel, for the best sound.
Posted on Jan 05, 2010
Testimonial: "thanks"
Hey names Nathan and I just got a kicker ZX300.1 and a I connected it to my kicker comp 12 and an alpine cde 102. So the problem is that the protection light flashes with the beat of the bass at high...
Your speaker wires could be shorting to ground at the subs or at the amp. You could be experiencing a drop in voltage when the bass hits. Check your power connection at the battery, fuse and amp. Check your ground connection at the chassis connection and at the amp.
Aug 19, 2012 | Car Audio & Video
How do I tune my KICKER 08ZX1000? I have the amp running to alpine type r 12 inchs at 2 ohms but I don't know where the bass boost , gain, and crossover knobs should be pointing or what one to turn up...
To start, turn the gains on your amp all the way down. Bass boost should be off (this us used if you listen to your subs at low volume, the boost will heat your amp up quick if you use at high volume). Then turn the volume on your headunit up to 3/4 full. Make sure the filter on your amp is on low pass. The crossover point should be at it's lowest too. With all these in place, you can begin turning up the gain. You will have to decide at what point to move the crossover point. Since there are different styles of music, you will have to listen to where you feel notes are "dropping off" from the music. Adjust the crossover point to your liking, but remember that subs were made to reproduce low frequencies. Hope this helps
Aug 20, 2011 | Kicker Car Audio & Video
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
My Mirage S10 subwoofer light comes on showing the subwoofer is on but I cannot get any bass sound to come on. How can this be resolved?
More diagnosis first. We can't assume the source is squawking bass to this thing and you don't mention that you know that to be the case. IS it? The problem could be up the food chain.
We also don't know if you're feeding it Speaker Level or Line Level.
Prove the subwoofer amp is dead or alive by jacking in any source you have that has an RCA output (Tape Out on your unnamed source, CD, TV, etc). Turn the sub volume down to minimum to start as most RCA outputs are at maximum volume. Try that to assess the amp's health. Still dead? Get it worked on.
Jul 07, 2011 | Mirage Prestige S10 Subwoofer Speaker
No bass
could be the speaker its hooked up to . try to disconnect the sub and see if the protect light goes out
Feb 06, 2010 | Competition INTERFIRE BIG BOY 2CH...
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
May 30, 2009 | Kicker ZX400.1 Car Audio Amplifier
Green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Mar 16, 2009 | Kicker (ZX750.1) Car Audio Amplifier
Alpine mrv-t757
Hi Big Nick,
Sounds like you have got almost all the good out of those Subs. You can find the screws you need at almost any hardware store or Auto parts store. The light is becase you are dloading the amp with low OHMS.  You may need use one channel and Run the wiring like written blow to get the power problem to disappear.
S1+ = Kicker comp cvr sub coil 1 positive
A+ = Amplifier Positive output.
A+ to S1+
S1- to S2+
S2- to A-
Oct 18, 2007 | Alpine MRV-T757 Car Audio Amplifier
Kicker 11PT10 100W Bass Station Loaded 10" Carpeted Subwoofer Enclosur Logo
124 people viewed this question
Top Kicker Televison & Video Experts
Electro Med Services...
Are you a Kicker Televison and Video Expert? Answer questions, earn points and help others
