Question about Canon Pixma MG6120 InkJet Printer
Cannon MG6120 printer will not print text. I have cleaned print heads several times. I think I have a clogged print head. Which of the 2 black ink cartridges prints text? How do I clean a clogged print head? Thanks.
  • 1,057 Answers
I think you need to do is reinstall you software driver for the print program and start with known parameters. Then you can try to clean the heads. You should get something out of the printer if the heads are plugged it might be a dot or smear on the paper.
Posted on Jul 14, 2015
SOURCE: MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Posted on Feb 25, 2008
tenorsax
SOURCE: Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Posted on Aug 17, 2008
SOURCE: How do I remove a Canon 730 Multipass print head
Press the button on the right hand side of the printer. Lift the lid, pull up the little gray handle. Rock the print head container a bit and you'll see a little metal bar. Grab that and pull straight up.
Posted on Jun 13, 2009
ThiruBulls
  • 103 Answers
SOURCE: cannon ink jet quit printing black
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel. # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right). # Continue doing this until it looks clean. # Then dab the cartridge on the towel to make sure the ink is flowing. # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier. 2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Aug 21, 2009
SOURCE: cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Posted on Nov 11, 2009
When I print the Black ink does not print on page at all. All of the colors cyan, magenta and yellow are fine. I haver replaced the Black Cartrige and Run the printers cleaning cycle several times.
maybe you run out of ink for black, try to use other ink, if its still the same then their a stockup ink on your head of the printer and better to replace it. I think once you purchase an ink cartridge of cannon their is also printer head included. Hope it helps thanks.
Sep 19, 2011 | Brother MFC 490cw Color Inkjet...
Color stopped printing, changed cartridges, still will not print color. Now my black ink cartridge is acting up by starting off not completely printing text. What do I do now, buy a new printer?
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 06, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Cannon MP520 when printing documents there are lines through some of the text. I have changed the ink cartridge 2 times! What should I do?
The issue is not with the ink cartridge but with the actual print heads. In most (almost all) Canon ink jet prints/multi functions the prints heads are separate from the ink cartridge.
The print head is what guides he ink onto the page, if they become dirty or clogged then you will get lines through images and text or very poor print outs.
You can clean the print heads by using the software that came with the printer and there are some other ways as well.
I tried to paste the instructions from Canons site but they were too long. Use the link below to go to Canon's knowledge base for the MP520 and search for "clean print heads" and follow the instructions that come up.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15483
Apr 14, 2010 | Canon PIXMA MP520 InkJet Printer
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
I am having problems getting my Printer to print text. It prints graphics just fine but it will not print text at all. I have tried cleaning and deep cleaning the Black 3eBK nozzle but this has not...
It's a print-head problem, the black nozzles are clogged out... sorry there is no remedy for this kind of problem..
But, try to ****-in air out from the print head's by using a syringe,
moz-screenshot.jpgno needle, on to the black ink tube, not the actual picture but I hope you got the idea. Then try cleaning again and a print test, keep doing this several times, but it would waste a lot of ink.
Hope this helps.
Aug 21, 2008 | Canon Office Equipment & Supplies
Black text d not print
If the printer has been left for some weeks with an empty black cartridge then I suspect the print head is clogged.
To clean the print head, firstly remove it.
Remove each cartridge quickly and turn it upside down so ink does not drip out.
Flush warm water with a drop of detergent through the metal meshes at the bottom front inside of the print head unit. Continue untill the water coming out of the bottom of the print head is clear.
Then flush through with clean warm water for about 30secs.
Shake as much water as possible out of the unit.
Replace the cartridges quickly to avoid ink dripping out.
Undertake a nossle (head) clean on the printer until printing correctly.
Hope this helps.
Jul 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
PIXMA MP780 - not printing black chararcters
All the people in this forum with a Canon ink printer not printing black, especially if you tried replacing the print head and still have the same problem.
Your purge unit/capping assembly is most likely clogged. This can be caused by using crappy ink cartridges and by not using the printer for exptemely long periods of time.
You will have to disassemble the printer. First open the lid so the print head moves into the centre of travel. Unplug the power cord. Remove the upper case (can be hard to do, usually they're snap-together).
Remove one screw on either side of the print engine and remove the engine from the lower case. Unplug the cables that go from the main board to the purge unit (the large black assembly covered with old ink, located on the right side of the printer where the head usually would stop after you've finished using the printer and shut it off).
Now you have to remove that black purge unit from the right side of the engine. Usually there are two screws holding it in place.
Give the unit a bath, carefully removing old ink from everything so the unit looks like new. (be sure to remove the one motor first or you will ruin the motor). Check the bottom and make sure the two small clear rubber tubes are not clogged with old ink. Clean the absorber off (the pad in the lower case) if it has ink piled into a small hill shape.
If the tubes look like they might be clogged, you'll have to find a way to clear them out. I can do it in my shop, but it's too in depth to explain.
Reassemble the printer, connect to a PC and do a few deep cleans and print out a test page. Problem solved.
Remember, if one colour is not working it's because the head is clogged. You will have to do multiple cleans to get it to work. If it still doesn't work, then either it's REALLY clogged or the purge unit is not working because it's clogged. If you buy a new print head, then the only thing left is the purge unit. Be brave and try the disassembly and cleaning, or take it to your local service shop.
We charge $45 CDN for a job like this.
Rule of thumb: If you can get it fixed at a shop for 1/2 prince of a new unit, go for it.
Jan 02, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Not printing black
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again...... Do not touch heads' copper poles and cartridges poles because of the static electric they may mulfunction and colours may becaome totally mixed for a short while...
Aug 22, 2007 | Brother MFC 210C All-In-One InkJet Printer
Canon Pixma MG6120 InkJet Printer Logo
257 people viewed this question
old marine
old marine
