Question about Husqvarna 28cc 2-Cycle Curved-Shaft Gas String Trimmer 952711952
No spark Working fine and just quit. Wouldn't restart. Running for only a few minutes. A pretty low hour machine. No hint of a problem. Just died. Check spark. No spark. Checked kill switch wiring. Disabled it. Still no spark. How common is a magneto failure?
    Sergeant:
  • 325 Answers
Mag. failure on husky`s is quite common, l had a similar problem with my husky chainsaw.l would on your`s try another spark plug first then check the mag....
Posted on Dec 31, 2012
Stalls losing electric power
How old is the battery & have you tested it?
How is it that a month went by & your using
any vehicle that could let you down?
Why have all issues not been resolved ,as soon
as they started?
Have you checked for codes?
Have you had a professional scan tool on it
& checked data,that has to be done along with
many other checks or tests,unless it's just a battery
issue.
No one can solve any vehicle issue over the internet
There is always more to the story & you need the patient
Jul 19, 2013 | 2004 GMC Envoy
I have a Yamaha Tach/Hour Meter 1/10. I cannot turn it off. Boat batteries are disconnected and I have disconnected the tach/hour meter. It keeps flashing
From what I have gathered on the internet, it doesn't turn off. When running it displays RPM, when engine off, displays run time. Estimate for the internal battery was 10 years, but I wouldn't bet on it. This is a sealed unit and priced low enough that after a few years it is a throw away. Liquid Crystal displays use very little power, micro micro amps, and it is possible that it is designed to charge itself when the engine is running off the pulses from the plug wire, micro amps at a time. All that said, I don't think you have a problem, just need to read the instructions and see if they say anything different, I couldn't find them online so hope you have them.
Sep 23, 2012 | Yamaha Delux Hour Meter & Tachometer
The engine on my 2000 MPV cuts out and dies when I press the accelerator. After it sits for an hour or so, I can travel for 20 min. or so before the problem starts again. HELP!
if its been a while change the fuel filter and then have the fuel pressure and volume checked.these symptoms are very common for a fuel pump problem.
Feb 07, 2012 | 2000 Mazda MPV
Husqvarna Model 51 won't start. Was running fine and has never had a problem starting (owned since new, 14+ years). Chain slipped off. Fixed and then saw wouldn't start. Good bright spark &...
If you have a good spark, and there is fuel at the plug, the only things to stop it fireing up are a sheared flywheel key knocking the timeing out, or the engine has low compression due to wear or damaged piston and ring.
Sep 07, 2011 | Garden
My husband's 2004 Cavalier stopped running at a red light. It wouldn't restart. He pushed it off the road and after work it wouldn't restart either. A friend told him about a fuel line reset...
its possible but it usually takes quite a bump or jar to set that off.
it helps to remember that a vehicle need 3 things to start
spark
fuel
air
spark is easy to see if your getting. have an assistant watch
remove one spark plug wire from the plug and lay the wire next to a metal nut or bolt on the engine
then crank the engine, the assistant should see a bright spark coming from the wire
fuel is easy but it takes the correct tool. buy or rent a fuel pressure tester. attach it to the fuel rail (where your fuel injectors are attached to) and check the pressure with the car on and the car off but the key on run (your local auto parts store can help you with finding the standard fuel pressure)
air is very easy, check your air filter. though I have never seen an air filter so dirty a vehicle wouldnt start,
finally if all those check out. either take it to a shop or check the timing belt yourself.
if your timing belt goes your vehicle would stop immediately and it wont restart till its replaced
Sep 03, 2011 | 2004 Chevrolet Cavalier
My Honda Accord 1995 will not start. One day the engine decided to only sluggishly turn (wouldn't crank) - then suddenly took off, turned over quickly and started straight away. I charged the...
When the alternator doesn't supply current, the battery light on the dash would light up. (assuming the battery lightbulb is working) Next would be to doubt the voltage regulator not doing a proper job, but usually its either dead or working.
Ghost consumers can be tracked when the engine is off and removing / attaching the battery lead causes quite a bit of spark. Measure the Amps with a multimeter when turned off. When it's in the 2 Amps and upwards region - remove one fuse group after the other to see where most of it goes. Then go through all the separate consumers in that group.
If it's a low current preferably below the 1 Amp - the battery might not be as healthy anymore as suspected.
Jul 01, 2011 | 1995 Honda Accord
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
Husqvarna 28cc 2-Cycle Curved-Shaft Gas String Trimmer 952711952 Logo
88 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
