Question about Electrical Supplies
Leviton IPI06-1LM 3 way dimmer switch- not dimming
I have connected my dimmer switch by following the diagram/instruction in the instructions. Somewhere along the way, I must have messed up, because now only the switch on/off works and not the dimmer. Here are some additional details about the room: I am putting a dimmer in the kitchen. Currently, there are two separate switches. One by the fridge and one by the door of the kitchen. Originally, they both just had on and off switches. Now, I am trying to replace the switch by the fridge to be a dimmer switch, so I purchased a three way dimmer. The wiring inside the wall consisted of white wires that were bundles together and capped (Two from top, one from bottom of wall). Ground wires from top and bottom connected together. One black wire and three black wires coming from the top. The bottom black wire was bundled with two of the black wires from the top and one of the top black wires was left by itself. There is also one red wire coming from the top of the wall. In Summary: I have a bundle of white wires capped, a bundle of black wires, one stand-alone black wire, one red wire coming from top, and a bundle of ground wires. I have attached the following to the wall from the switch: -Green wire from switch to Ground wire in wall. -Black wire from switch to bundle of black wires from wall. -Red Wire (used in 3-way installation-tagged) from switch to the red wire in wall. -Red wire from switch to the standalone black wire in wall. What have I done wrong? It turns on and works fine with the second switch near the kitchen door, but no luck in dimming. Additional information: I have four halogen bulbs in my receding ceiling lights.
  • 3,287 Answers
Hi Sara,
Please read this entirely before attempting.
I am an electrician and would like to help you with this problem. You have provided great detail of your situation, yet I am confused about the statement describing how you wired it:
"-Red Wire (used in 3-way installation-tagged) from switch to the red wire in wall."
Before checking wiring, be sure to shut off the power to the circuit.
The "tagged" wire should be the one you identified with tape (when you removed the original) that was connected to the dark colored (called a "shunt" or "common terminal") screw of the switch.
In a 3 way installation, both red wires from the dimmer switch are used. In a single pole installation, only the UNinsulated red wire is used and the insulated wire is not.
To which wire do you affix the "tag"? If it was a short wire that ran between the the bundled black wires and the shunt terminal screw of the old switch, then the dimmer switch's black wire should be combined with these bundled black wires. One of the dimmer switch's red wires would be connected to the red wire in the box and the dimmer switch's last red wire would be connected to the remaining black wire in the box. I understand that this is the way you have it currently wired - but without being able to dim.
If this is all correct, did you check / change the Minimum Brightness Adjustment setting for the switch as detailed in Step 7 of the directions?
"This Dimmer incorporates a
minimum brightness adjustment
that allows you to set the level of
light when the slider control lever is
in the lowest position.
Move slider to the lowest position.
Using a small, insulated screwdriver,
rotate the adjustment screw as
shown until the desired level of
minimum brightness is obtained."
I hope this helps and good luck!
Posted on Jan 16, 2013
badenhop
  • 44 Answers
SOURCE: Single Pole Dimmer Installation
I'm not sure if this is going to work in your case, but I'm pretty sure it will...
Green to ground (probably bare)
Black to black
White to the red that's not labeled 3-way
wire nut on the red labeled 3-way
That should fixya!
Posted on May 30, 2009
VtToolMan
  • 704 Answers
SOURCE: replaced existing Lutron skylark low voltage dimmer
You will need to return the 3-way dimmer and get a single pole dimmer, as the Lutron Skylark series is suspectible to failure if connected to a live circuit first, or misconnected at intial installation. As an electrician, I ceased using these dimmers years ago, due to the rash of call-backs by customers and went with Leviton togglers and have had excellent results.
If you purchased it at a 'big box' store, they will accept the return as a defective item, as they have national agreements with their suppliers to accept customer returns. Just tell them it didn't work and you want a store credit, you can then purchase the lower priced single pole dimmer you need and save some money in the process too.
Hope you find this Very Helpful - best regards!
Posted on Aug 19, 2009
Testimonial: "I appreciate your help."
bschilz
  • 2049 Answers
SOURCE: Have a Leviton dimmer with red, black and green
You are correct in assuming green is the ground and connects to bare copper wire. Black is always the HOT wire and should be attached to the black wire. Red wire connects to white wire.
Posted on Sep 13, 2009
  • 3940 Answers
SOURCE: The task was to replace
Alan
Generally, 3 wires indicate a "3way" switch where you have 2 switches at opposite entrances to a room. Both the Red and Black Can be hot, depending on the other switches position. But, a red wire would normally only be found at the switch box not the light.
What I'd suggest, is that you get a multimeter, and use it to determine the hot wire and the ground/neutral. Once you know which wire is hot, connect the hot to the black lead, and ground/neutral to the white lead of the light. That is the only SAFE manner I can see to resolve this.
Posted on Mar 02, 2010
mkh5094
  • 145 Answers
SOURCE: 3 way dimmer turns on and off, but does not dim
All your wiring looks good. Many times dimmer just have problems and are faulty. You should note that the dimmer can only handle 600 watts. If you have that or more on it, than you have probably fried the dimming mechanism. In either case the dimming mechanism is not working properly and you will have to take it back and get the same dimmer or a different one. Tell the store they sold you a faulty dimmer and you can get a replacement at no cost.
Posted on May 29, 2010
Dimmer does not work
A 3-way light switch needs 3 wires for both switches to work correctly. If there is only 2 wires on the switch, its not a 3-way. Only two black wires on the switch means it can be wired either way. The power and light leads are inter changeable. If you really need a 3-way switch, be sure it is labeled as that on the box and look for 3 connections on the switch its self. Else, try a switch rated for a higher amperage.
Nov 30, 2011 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
I bought a Leviton 1201-PLC 15 Amp, 120 Volt, Toggle Pilot Light, Illuminated ON to replace a traditional 3 way switch (without a pilot). I replaced it by connecting the existing wires to the new switch in...
Your screw terminals are 2-brass and 1-dark.
Dark screw is considered 'common'
http://waterheatertimer.org/ST01C-program.html#3-way
Leviton shows a 3-way 1203-2, but not 1201
Wiring diagram indicates that pilot light is ON whenever switch has power.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=2681§ion=10046&minisite=10026
Check your instruction sheet that pilot light is supposed to turn on-off with Load.
I don't think it is, without additional terminal on switch for neutral wire.
And then it would only work on switch located closest to light.
You can wire this type of thing separately.
Buy ordinary pilot light or indicator light from WW Grainger.
Look at diagram on following image:
http://waterheatertimer.org/images/3-way-circuit-with-pilot-indicator.jpg
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 08, 2011 | Leviton Snap On Mount Switch Pilot Light -...
I just installed a Leviton IP106 Illumatech dimmer switch. It was replacing my existing rotary dimmer switch. The switch is a 3-way wiring job, with another 3-way toggle switch (no dimmer) on the other...
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Dec 22, 2010 | Leviton Decora Light Dimmer Switch
My rotary dimmer doesn't switch 3-ways. I have to push the dimmer button to "on", then I can use the other switch to turn on/off.
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
Nov 30, 2010 | Leviton Decora Rotary Dimmer 600-Watt SP...
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
Need to hook this up to a lutron eco-t528-277-2 ballast which only has a hot,dimmed hot and neutral
If I understand correctly, you have Leviton florescent dimmer
And you want to connect dimmer to Lutron ECO-series ballast
This is the ballast with 3 wires: Hot dimmed, Neutral and Hot
Is this your dimmer???? Has Black, White, Red, Yellow-red, & Orange
Here's how to do it:
Dimmer yellow-red is not used except for 3-way switch >> cap it off with wire nut
Dimmer orange wire connects to ballast Dimmed Hot
Dimmer red wire connects to ballast Hot
Dimmer white wire connects to ballast Neutral
Those are your wires going to ballast. As you can see, you need 3 wires going to florescent fixture
Next, let's focus on Dimmer:
Dimmer green wire goes to bare ground wire
Dimmer black wire connects to Hot from breaker box (we'll test for that next)
Finally the Dimmer white wire connects to ballast Neutral as discussed above BUT is also has to connect to Neutral from breaker box
This means the Dimmer white wire is connected to 2 wires >> one wire goes to florescent fixture and the other wire comes from breaker box
So which wires come from breaker box??
It should be a black and white wire.
Let's test to find Hot and Neutral that come from breaker box.
Mark your wires.
Disconnect all the wires and separate from each other
Turn on power
Use ordinary tester
Tape tester leads to wood sticks so hands stay away from electricity
Power is on
Test each wire to bare copper wire
When tester lights up, that is Hot from breaker box ... this wire connects to Dimmer black wire
Now, test the hot wire to each of the other wires
When tester lights up, that is Neutral wire ... this wire connects to Dimmer white wire, and also connects to Ballast neutral.
Connect one wire at a time, and it will work.
Oct 04, 2010 | Leviton Decora Light Dimmer Switch
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Electrical Supplies Logo
144 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
