Question about Poulan 14" Electric Chainsaw
Poulan chainsaw pull cord kickback - Poulan 14" Electric Chainsaw
  • 14 Answers
SOURCE: Chainsaw pull cord won't pull to start
Simply check to see if motor is locked is to remove spark plug and try to pull start. If motor turns, then he may have gotten gas in cylinder and created hydraulic lock. If moto does not turn, it is just a few screws more to take side cover off and see if rope caught in pully. In fact, you may want to take side cover off first, and make sure rope pulls out of housing, and self winds, like it should. At hat point, he can simple turn flywheel by hand to see if motor is locked up.
If the motor is locked up, you can put small amount of motor oil, (half a tea spoon) into spark plug hole, let it sit half an hour or so, and then try to work the flywheel back and forth to break it free. This condition may have been caused by running straight gas, not mixed. And, even if motor frees up, it may still need to go in for repair.
We have a couple of Poulin Pros at this saw mill where I work, and have had the piston lock up more than once, from guys dumping in straight gas. Sometimes we'ra able to free up piston, and make saw run again. And sometimes we end up tearing it down and repairing piston ring. Good Luck
Posted on Nov 19, 2008
  • 2692 Answers
SOURCE: Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Posted on Jan 24, 2009
dontbother10
  • 2220 Answers
SOURCE: pull cord on poulan chainsaw is bound up....wont
Determine if the warranty is active first. Most warranties are effective for 1 to 5 years. If yes return it to where it was purchased or find an authorized repair facility. A written diagnosis by a good independent saw shop ($10-20) might be a good idea at this point. It is difficult to argue repair charges with an authorized repair facility without some documentation in your favor.
1. Remove the starter housing. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if no repair starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required? If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated without oil mixed with the fuel?
· Remove the spark plug wire and plug.
· Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and inspect the cylinder, above the exhaust port, through the spark plug hole. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by the independent saw shop should be considered.
4. The final likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
Posted on Oct 23, 2009
dontbother10
  • 2220 Answers
SOURCE: i need to install a new spring for the pull start
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Posted on Nov 01, 2009
cmcduncand
  • 714 Answers
SOURCE: I have a 16 inch gas poulan chainsaw. I can't
Hi Speed circuit clogged in Carb.
Remove clean and soak blow out jet, Replace spark plug.
Also verfi Oil mix, add a fuel stabiliser if using fuel with ethanol.
Hope this tip helps.
R/
David
Posted on Jan 29, 2010
#pp5020av pull cord
The length of the Starter pull cord is 40"
It can be purchased at www.ereplacement parts.com
I have no affiliation with this site or company. They simply have great prices and also list exploded views of this saw and others.
http://www.ereplacementparts.com/poulan-pp5020av-stroke-gas-chainsaw-parts-c-16962_17147_162366.html
Aug 04, 2014 | Poulan Pro Pp5020av Gas Chain Saw 20" 50cc...
What is the replacemnet cord size for my #pp5020av
www.ereplacementparts.com lists the part as Kit Rope 40" (Type 4.5)
Part Number: 530069919 Priced at $2.84 and if you need a new handle, it's only $2.73
The link is below.
Aug 04, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
I have a Poulan PRO LINK PP 335 and the pull rope is only coming out about 8 inches. It's stuck...what should I do?
Remove the starter and pull the cord, if the cord still only comes out so far it is either the cord is too short ( replace the cord ) or the rewind spring is coil bound ( release some of the tention )
Apr 23, 2011 | Poulan Garden
Jammed pull cord on Poulan P4018 chainsaw!
There maybe a split pin holding the cover down over the spindle! Not too sure, but possible. Could be pushed down the centre, just a case of having a good look. Only really worked with Hurqvarna's and Makita's. Hope it helps. Good Luck
RICH
Dec 16, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
What type of chain does a 18" poulan wildthing use?
It depends on the what the operator wants to use.
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
A low kickback chain is the only one offered by Oregon. A local chainsaw shop can give you some more aggressive chain. Take your old chain with you to use as a template. HTH
Lou
Oct 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 16" cannot start...pull cord locked up
Remove the cover, should be 4 screws that holds it on once the 4 screws are loosened the rope could rewind on its own. If not check to make sure the spring is not broken.
Apr 06, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 14" Electric Chainsaw Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
