Question about Sony Cyber-shot DSC-W30 Digital Camera
Memory card problem
Hi Took my memory stick into local boots to get a few prints done,usually download them myself on my computer.The memory stick wouldnt upload any images the youmg girl finally gave up. So i put memory stick back into camera and went home, that evening was going to show a friend the pics on my camera when turning it on message comes up ACCESS. After turning on and off a few times starts beeping and message comes up INSERT MEMORY CARD.Done this a few times with no joy.HELP Very important pictures of my dads 65th birthday only person who took pics, need to know i havent lost them.
    Genius:
  • 2,985 Answers
Download PC Inspector from www.convar,com run the stick through this program- if the images are there it will find them But of course no images may have been recorded Sony Tech Help Team will tell you more about the meaning of 'Access'
Posted on Jun 23, 2007
SOURCE:
Only long beep tones with a few seconds pauses
depending on the beeps, you are looking at usually memory or video card error. first step is to remove the memory from the system and place only one stick in at a time. if the unit only has one stick then you need to get a known workign stick to test with. if the known working stick works or only one of the other sticks work then check each of the slots indvidually. if you find that the unit does not boot with the memory in a specific slot, then you have a bad motherboard. if the unit boots in every slot with the good memory, then you have a bad stick. If the pc boots after pulling and reseating the memory, you got one of the rare issues of a memory stick lossening up. If nothing boots it, then you need to move on to either the video card or motherboard.
Without the exact beeps and length of each beep i could not give you more than a generalized answer.
Sep 07, 2011 | Compaq Presario 5000 PC Desktop
Can the memory card reader in the HP C5150 printer read a sdhc memory card?
Your printer only supports the following:
Memory Stick, Magic Gate Memory Stick, Memory Stick Duo
(with user-supplied adapter), Memory Stick Pro, xD-Picture Card, Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card, CompactFlash (I, II).
But, you can use your SDHC memory if you purchase an adapter for it or a card reader so you can connect it to the computer and print whatever you need to print.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button and leave ashort comment in return. Have a good one!
Jul 20, 2011 | HP Office Equipment & Supplies
Turn on computer, hear beep beep beep. then monitor does not come on, says no signal. looking at black screen only
3 beeps is usually a memory error. In fact, it means there is a failure within the first 64KB of system memory. You can usually find out if one of your ram sticks is bad by taking a stick out and turning the PC back on. If it boots, you found the bad ram. If not, replace and try again.
Once you can ever get it to boot, you can go to memtest (http://www.memtest.org/) and download the auto installer for USB key and boot from USB (usually by pressing f12 or del, depending on your bios...it will say on boot up). This will tell you if you have any further ram issues.
If this doesn't resolve your issue, the other option 3 beeps can mean is a bad motherboard or other system device (worse case scenario, and fairly rare).
Hope this helps...
Jan 03, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
Memory stick pro duo
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format stick pro duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
I HAVE 2004 SILVER PSP CFW 5.50. HOW DO I PLAY DOWNLOADED GAMES ON IT. WHAT SOFTWARE TO INSTALL AND HOW?
Hi. First, you have to format your memory card so that the required folders will be automatically created.
On your PSP, go to Settings>>System Settings>>Format Memory Stick. Select YES when asked if you really want to format your memory stick. Wait for a few seconds & once prompted that it's done, you can now grab your USB cable and plug your PSP to a computer.
Go to Settings>>USB Connection. Your computer will detect the memory stick as an external drive. Once connected, navigate to your PSP's memory card directory via Windows Explorer. You should see an "ISO" folder. Open this and copy your downloaded games here (.iso or .cso file).
Safely remove the USB connection once done. Navigate to your "Games" on the PSP and the copied game will appear.
Hope this helps.
Aug 24, 2009 | Video Game Consoles & Games
My computer can't read pictures from memory stick pro duo
there or to picture folders on the psp one is in the root of the memory stick and the other you have to open the memory stick then open the folder called PSP
Aug 04, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Trying to log on to Dimension 2400, but won't come on power is going thru. AB light in back is yellow
Okay, That helps,
What did you do to the computer *prior* to this issue?
You need to look at a few things. Remove all memory sticks except one.
Try to boot. If it does work, then you have a bad memory stick.
Add another stick and so on.
if you have a Video card in a slot, remove card and relocate to another slot (IF RAM does not fix).
Make sure CPU is fully seated as well.
Can you boot to safe mode using F8 ?
lets get the first 2 things done first tho.
Thanks for the fast reply!!!
Feb 22, 2009 | Dell Dimension 2400 PC Desktop
Won't run
you have,nt seated the memory module back correctly.
push module in at an angle, usually about 45 degrees.
while pushing it back in, apply pressure, to push down towards the motherboard. ** check for any specs of Dust**
also check that you have,nt knocked the hard-drive ribbon cable in the process of cleaning.
Mike @ Compurepair.
Feb 23, 2008 | Toshiba Satellite A85-S107 Notebook
Need help think i may need a motherboard
If the the laptop is failing to boot very early in the4 boot sequence, then this usually points to a failure somewhere on the motherboard. There are a few test you can run to try. 1) Try downloading the following Diagnostic program and running it on your computer. The download makes a bootable CD, and you can try running a bunch of diagnostics on your computer with out having to boot into Windows. You can test memory, the hard drive, and other things. http://www.ultimatebootcd.com/ 2) Try replacing the memory. Sometimes bad memory can cause a device not to boot. 3) If neither of the above suggestions work, then I'm afraid you will need a new motherboard.
Oct 01, 2006 | Toshiba Satellite A25-S207 Notebook
Sony Cyber-shot DSC-W30 Digital Camera Logo
103 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
